Old 03-17-2013, 04:24 PM   #1
Dnrice
Help!! 35 degrees BTC
Hey everyone, worked on 350 small block with delco remy distributor and my timing says it is 35 degrees before top center. I bought timer from Advance Auto since it has been backfiring through the carb when under load. If I try to get it around 15 it will stall. Any advice? It has cam and is camel hump. Thanks, David
Dnrice is offline   Reply With Quote
Old 03-17-2013, 04:48 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: Help!! 35 degrees BTC
The first thing to do is to make sure that your timing mark is correct. Take #1 spark plug out, roll the engine so that the piston is at top dead center. Check the timing marks and make sure that they line up. If not, remark them. I have found that with a performance cam, they like a lot of advance. I set the initial at 10-15 BTC, connect the vacuum advance to manifold vacuum. Install an advance kit in the distributor. That should work. Run premium fuel with octane boost if you have any detonation problems. The 35 number is for total advance.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 03-18-2013, 06:54 AM   #3
Dnrice
What advance distributor kit are you using in your distributor?
Old 03-18-2013, 07:56 AM   #4
cdowns
cdowns's Avatar
if your timing marks is correct sounds like the dizzy has been installed a tooth or three off
Old 03-18-2013, 08:17 AM   #5
Dnrice
Very good point.
