Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-17-2013, 08:46 PM   #1
redsled87
redsled87's Avatar
front rotors
Has anyone had there rotors drilled for the 5 on 4/3/4" car pattern? I'm supposed to take my roters to the machine shop Tuesday. I pulled them off today and, it doesn't look like enough room for the stud on the inside of the rotors. Is there any company that sells them already done? Maybe there is another application that fits and has the bolt pattern that I want. I have the heavy duty brake option by the way.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 03-17-2013, 11:36 PM   #2
Captainfab
60-66 Nut
Re: front rotors
Other than going with aftermarket big brakes, the only way I have heard of is in this thread. But you would have to change your spindles.
http://www.67-72chevytrucks.com/vboa...d.php?t=319487
It might be easier and less $$ to just have your rotors machined and drilled. I believe in order to drill the secomd bolt pattern, the ribs on the inside need to be machined out.
Old 03-18-2013, 12:35 AM   #3
redsled87
redsled87's Avatar
Re: front rotors
Thanks captainfab. I was affraid of that. Since my truck used to be a delivery truck, it has the heavier brakes on it. Machine shop here I come.
60' 1.49
1/4 10.93
MPH 120
Old 03-18-2013, 06:38 AM   #4
regan wilson
regan wilson's Avatar
Re: front rotors
I did it years ago and so I could get a 3.5 wheel and it worked fine. I ended up later going to Strange brakes
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 03-20-2013, 04:24 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Re: front rotors
Yes, I drilled mine many years ago to fit a set of vintage 4.5 wide wheels up front.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
