Old 03-17-2013, 09:12 PM   #1
Davemotohead
Davemotohead's Avatar
71 4x4 T-350-c99404 transfer case Question?
71 chevy with turbo 350 and C99-404 transfer case,,it has been leaking so went to put gear oil in it to top it off,,BUT noticed the speedo cable has ATF dripping off of it and when I opened the fill plug it appeared to have ATF in the transfer case? Does this transfer case share ATF with the trans? I thought it would take Gear oil? Thanks
edited by staff
Davemotohead is offline   Reply With Quote
Old 03-17-2013, 11:48 PM   #2
Davemotohead
Re: 71 4x4 T-350-c99404 transfer case Question?
OH! and how do I clean my washer Jug?
edited by staff
Old 03-17-2013, 11:59 PM   #3
mud.man.rj
mud.man.rj's Avatar
Should be a seal inbetween the two, so must be leaking thru. Have you ever changed the t.case oil maybe someone used atf in it.
mud.man.rj is offline   Reply With Quote
Old 03-18-2013, 12:04 AM   #4
Davemotohead
Have never changed it,,after doing some reading I guess you can run anything you want in the 205 transfer case? since it seems to have ATF in it was thinking of just topping it off with some dextron,,seems you can just pee in these things and it will work?
edited by staff
Old 03-18-2013, 08:56 AM   #5
They started running Dextron in the NP203s (full-time transfer case) when they came out. And,about that time,they started saying Dextron was good for gear oil because of improvements to it's formula.
Old 03-18-2013, 06:38 PM   #6
mud.man.rj
mud.man.rj's Avatar
I always use synthetic in my gear drives and standard trans, Atf may work well but never went that way but if it is leaking threw from the auto trans what would it hurt, just make sure the trans isn't pressuring it threw to the t.case overfilling it and the trans going low, may not happen but something to watch for.
