Old 03-17-2013, 10:33 PM   #1
rs74
rs74's Avatar
How does this trim come off.
I am trying to get the corner bed trim off. I took out the tail lights and can see a clip towards the inside of the bed and a nut towards the outside. The nut is just spinning and seems like I am getting nowhere. Does the nut have to come off first. I was going to try and get it off the clip to be able to put some pressure on the nut to see if it would help get off. Can these be bought aftermarket. I am scrapping the bed and was wanting to keep them. The rest it looks like it just stick on trim and this is the only pieces that actually bolt on.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-17-2013, 10:54 PM   #2
AntiGov
AntiGov's Avatar
Re: How does this trim come off.
you got the right idea see if you can pull out a bit on the trim to put outward pressure on the nut while you are turning it....i believe you can use needle nose to close the tabs on the other clip, once that one is off you may be able to slide it off the clip with nut
88 3+3 454 400 205 410 drw to srw still in pieces
90 3+3 350 400 205 410 srw
84 1/2 ton lb 6.2 4x4 parts truck
AntiGov is offline   Reply With Quote
Old 03-18-2013, 09:17 AM   #3
rs74
rs74's Avatar
Can this trim still be purchased new anywhere. Aftermarket?
Roy
1987 R10 shortie
