Old 03-18-2013, 01:01 AM   #451
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Originally Posted by Mattman2010 View Post
Dieselwrencher sent me a pic of your turbo he is sending you. He wouldn't send it to me instead trucks looking good man! Glad you came to the manual side!
Should make a reasonable set of twins. just enough to whet the appetite and get me all amped up for a real set!
Oh yeah, you might look into a industrial Manifold like what I have. It has the turbo farther forward on the engine. I might be able to stick a 5" down pipe on mine.
already in the works my friend. i am going to make an adapter that will lower the turbo slightly from the forward location and make it real easy/clean install of the primary. should also give me a place to locate the external gate if i feel like going that route. i already drew the T3 flange, so hopefully i can get those waterjetted this week. by the looks of it i'll be able to hog a 5 incher through the tangle too. i also have a sweet plan for my BHAF
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-18-2013, 03:15 AM   #452
Mattman2010
Mattman2010's Avatar
Re: 72 k20 project
Well sounds like you are in your way to figuring it out!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 03-18-2013, 02:35 PM   #453
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Originally Posted by ryanroo View Post
and this is how i plan to deal with the fact that i cant use the lower bushing. the purpose of the lower bushing is to allow for some chassis flex without torquing the cab to hard. these springs will allow for the same thing and i will just bolt from top to bottom. the plan isnt finished, but you get the idea
ryan
Uh, I doubt your chassis will flex much to get you worried about that.
Ryan
1969 Chevy milk truck
Old 03-18-2013, 10:01 PM   #454
ryanroo
ryanroo's Avatar
Re: 72 k20 project
We can hope not!
got a special box from the man in brown
72 K20 12v build
Old 03-18-2013, 11:31 PM   #455
Dieselwrencher
Re: 72 k20 project
Oh boy, there won't be much room when air fills those boys.
Ryan
Old 03-19-2013, 11:54 PM   #456
ryanroo
ryanroo's Avatar
Re: 72 k20 project
the one on the right has some air in it. just enough to lift the bag up to the frame.
72 K20 12v build
Old 03-20-2013, 03:15 AM   #457
argonaut
argonaut's Avatar
Re: 72 k20 project
Wow those things look gargantuan under there!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-20-2013, 08:03 AM   #458
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thats what i thought too!
72 K20 12v build
Old 03-20-2013, 02:54 PM   #459
Mattman2010
Re: 72 k20 project
Looking good man!
Build Thread
Build Thread
Thread
Old 03-20-2013, 04:26 PM   #460
mjensen
mjensen's Avatar
Re: 72 k20 project
Wow, this project is looking awesome! Can't wait to see more.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-23-2013, 07:53 PM   #461
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks Guys.
it is supporting itself again! the bags are huge, it should ride well, when the truck finished and heavier than it is now, it will be carrying little pressure in the bags. also means it will carry WAY more than the axle/truck is rated for...
now i need to measure/design the panhard stuff. ill order the rod ends sometime and probably some bilsteins as well. i still have to fab up the upper shock mounts.
anyhow
Ryan
72 K20 12v build
Old 03-23-2013, 08:02 PM   #462
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
WTF! That's awesome! You can start a business towing mobile homes with that rig. I know nothing about bags - can you control the ride height from inside the cab?
Old 03-23-2013, 09:29 PM   #463
woodwright
Enjoying left field
woodwright's Avatar
Re: 72 k20 project
Originally Posted by DeadheadNM View Post
WTF! That's awesome! You can start a business towing TRAINS with that rig. I know nothing about bags - can you control the ride height from inside the cab?
Fixed it.
How much are those bags rated for?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-23-2013, 09:37 PM   #464
Mattman2010
Re: 72 k20 project
Looking good man!
Build Thread
Build Thread
Thread
Old 03-23-2013, 11:28 PM   #465
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Hahaha. it may actually handle a mobile home pretty well if the rest of the truck could...
the "normal" bag set ups that the lowered crowd use usually have in cab controlers. they are basically pressure settings that will adjust the height of the bags and therefore the truck based on the pressure in the bag. i will set mine up to maintain my chosen ride height automatically. it is pretty much a self contained system that requires only the initial setting and is totally mechanical. i will have a dump switch in the cab that will allow me to dump the bags for easy trailer hookups, and i will probably have a bag pressure gauge and a tank pressure gauge just to know. after you have hauled some loads, you can use the bag pressure required to maintain ride height as a decent gauge of load weight.
Originally Posted by woodwright View Post
Fixed it.
Hahaha, you guys crack me up
i think the bags are rated somewhere close to 8k per bag. its like 7830 @90psi with a max pressure of 100psi operational. i think the dodge rating for the axle is 8k and the dana rating for 80s is like 11k. it will handle well over the axle capabilities with the suspension for sure.
Looking good man!
Thanks my friend
72 K20 12v build
Old 03-24-2013, 02:30 AM   #466
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
Can't wait to see what you come up with for the panhard, because the rest looks killer!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-24-2013, 07:05 PM   #467
ryanroo
ryanroo's Avatar
Re: 72 k20 project
had to measure for the panhard but had to figure out what would be where for when the bags where dumped and make sure my panhard wouldnt hit everything. i was also positive the diff would hit the gas tank as well.
here it is "aired out"
wheel stays centered!
cleared the tank. id like to say i had it all planned out, but i was mostly guessing
where the panhard has to live
72 K20 12v build
Old 03-24-2013, 07:06 PM   #468
ryanroo
ryanroo's Avatar
Re: 72 k20 project
and, the links while its all wadded up
72 K20 12v build
Old 03-24-2013, 07:08 PM   #469
RatRod68
RatRod68's Avatar
Re: 72 k20 project
looks great brother
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 03-24-2013, 08:07 PM   #470
Mattman2010
Re: 72 k20 project
Sweet! That's awesome buddy. That's going to be bad ass!
Build Thread
Build Thread
Thread
Old 03-24-2013, 08:38 PM   #471
Dieselwrencher
Re: 72 k20 project
Looks awesome! Do you have plans to set up the pan hard bar low to allow exhaust pass through? Your fuel tank worked out perfect too! Great work!
Ryan
Old 03-24-2013, 10:10 PM   #472
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks guys
I have no plans for exhaust right now. i think a hood stack.... really i have no idea. there is a giant wall when you get to the fuel tank, and no real good way to get through it. i have a decent chance of getting over the rail for an in front of the rear tire exit. that or the pointed at the ground ahead of the rear axle and make sure everything is washed and coated in WD40 every third day. i could also bail on the rear tank and go back to incab, but F that.
the bar will be low, but that is more for the RC than anything. i am pretty much bent over no matter how i roll for exhuast
Ryan
72 K20 12v build
Old 03-30-2013, 09:22 PM   #473
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Did a little fiddling with my panhard brackets today.
in effort to maximize the length of the panhard, it is really close to the drivers side link mount. i may have to untack it and slide it slightly to the inside if the rod end and the link bolt make sweet sweet love. i will find out when the ends get here
also got a trans mount fabbed up a while ago
mig weld
i have ordered all of my rod ends and bushings. hope to see them next week, but im not gonna hold my breath on the stuff from balistic. i imagine the parts from ruffstuff will be here by the end of the week.
72 K20 12v build
Old 03-31-2013, 09:51 PM   #474
RatRod68
RatRod68's Avatar
Re: 72 k20 project
is it weird if I get a chub looking at those welds?
build Threads:
Leftovers 68 C20
Semper Fi
Old 03-31-2013, 10:16 PM   #475
Mattman2010
Re: 72 k20 project
Not at all. Im jealous too.
Build Thread
Build Thread
Thread
