Old 03-18-2013, 06:36 PM   #1
sqrlnts
Remote entry / door locks
Anyone use the remote entry, electric lock kit from LMC? Currently my 57 doors do not lock with the key but need to change that as I am wanting to install my stereo equipment.
Looking for details like what you like and dislike about this or comparable systems.
Thanks in advance.
sqrlnts is offline   Reply With Quote
Old 03-19-2013, 12:12 PM   #2
_Ogre
_Ogre's Avatar
Re: Remote entry / door locks
are you shaving the door handles?
shop air compressor timer
Old 03-19-2013, 03:01 PM   #3
sqrlnts
No plans to shaved the handles Ogre.
Old 03-19-2013, 10:37 PM   #4
agnes the dog
agnes the dog's Avatar
Remote door locks would be nice. Not looking to shave the handles either, just something to unlock/lock without the key. Looking forward to find out what others have done!
agnes the dog is offline   Reply With Quote
Old 03-19-2013, 10:53 PM   #5
sqrlnts
Really, I am suprised no one has installed remote power locks. The kit is only $70.
Old 03-19-2013, 11:29 PM   #6
oldcouple
oldcouple's Avatar
Pretty sure that kit is more work than you think, most likely need to change out the lock system to bear claw style latches.
http://www.customclassictrucks.com/t...s/viewall.html
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 03-20-2013, 01:07 AM   #7
NEWFISHER
NEWFISHER's Avatar
I have installed a bunch of universal elec lock kits on several of our classics, the burb is the only one I haven't done one on yet. My wife CAN NOT LOCK A DOOR BEHIND HER so its been out of a need for security to install them and just click the remote. All of the cars and trucks were different, the kits or single pieces were the same. You just have to be able to attatch the long rod to the locking mechanism. Wether you weld it on, drill a hole in a pre existing latch or use the supplied barrel nut to fasten an existing lock rod to the supplied rod....its the only thing that matters. The rest is easy. Mount the electric actuator inside the door, attatch the other end of the lock rod, power the actuator with the trigger wire from the reciever, mount the reciever and supply 12v to it and a ground. I had looked into some threads here, stovebolt, hamb etc on elect locks using OE A.D. truck latches and came to the conclusion most went with bearclaw ( that doesn't give you a mechanical lock) or the other guys( can't remember the name) that gives you the ability for both. I haven't torn my latches apart yet to look, but am assuming if I did try to tag a moving part of the locking mechanism , I would most likely have to weld a finger or small bracket to the lock to get a rod to attatch to it if I wanted to stick with the OE set up.
NEWFISHER is offline   Reply With Quote
Old 04-11-2013, 12:54 AM   #8
sqrlnts
Thanks Newfisher, where did you purchase your kits?
Old 04-11-2013, 01:37 AM   #9
NEWFISHER
NEWFISHER's Avatar
Flea bay, crutchfield, amazon etc.
