Old 03-19-2013, 10:18 PM   #1
63chevy4x4
63chevy4x4's Avatar
Starter harness 61 GMC wire ID
I have a 61 gmc and I didnt have any underhood harnesses so i pulled from other trucks and put one togeather but I am having problems with my starter ignition power harness. Im wondering about the 5 blade plug on the passengers side, I have a light green, dark green, brown, wire and a largeer (about 10ga) red and purple wire. I have the red wire for powering my ignition and the feed from the starter and the purple to engergize it, obviously i have it scerwd up, i get nothing when i hit the key, any help would be great!
63chevy4x4 is offline   Reply With Quote
Old 03-20-2013, 01:09 AM   #2
rawraw67
rawraw67's Avatar
Re: Starter harness 61 GMC wire ID
I had this same problem last week.just lock back and find my post (1964 c10 starting issue) there are a few engine harness so make sure you have the right on
rawraw67 is offline   Reply With Quote
Old 03-20-2013, 12:21 PM   #3
pcsparts
The harness on the left is a Chevy harness with warning lights, not a GMC. They are altogether different. The red wire in the GMC is the main battery power feed coming into the truck off the starter. The Chevy pulls it's main battery power thru the front light harness. That is why the red wire is not there in the harness on the left (Chevy). Also the light green wire is the cold lamp wire for the Chevy with hot and cold idiot lights. The GMC harness does not have that wire as they all had live gauges. The Chevy harnesses are available new, but the GMC's are not.
Donny
pcsparts is offline   Reply With Quote
Old 03-20-2013, 12:37 PM   #4
63chevy4x4
63chevy4x4's Avatar
Thanks! that makes alot more sense, I wired it up using a Chevy manual, the plug i have is also from a 61 gmc, here is a pic of it
Old 03-20-2013, 12:38 PM   #5
61K10
61K10's Avatar
make sure the purple wire is on the inside terminal (close to eng) on the solenoid. and you have power to your ign s/w.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-20-2013, 12:47 PM   #6
63chevy4x4
63chevy4x4's Avatar
So i wana run the red wire to the battery cable lug on the starter, the purple wire to the terminal to the soleniod on the starter to energize it right? and just leave the other wires be?
Old 03-20-2013, 12:49 PM   #7
63chevy4x4
63chevy4x4's Avatar
I currently have the purple as power to the solenoid, wich wire would I use to power the coil? or would it be just as easy to run a wire off the fuse terminal to run that?
Old 03-20-2013, 04:39 PM   #8
61K10
61K10's Avatar
need more info--what distributor? points? still have a ballast resistor? the coil + becomes hot with key on (test wires) the out side term on the solenoid goes to the ballast res. so you get 12 when cranking. a gmc guy should chime in here???
1961 chevy K10
Old 03-20-2013, 04:56 PM   #9
63chevy4x4
63chevy4x4's Avatar
im running a mallroy unilight with a ballast resistor and power filter
Old 03-21-2013, 08:17 AM   #10
63chevy4x4
63chevy4x4's Avatar
dose an GMC guy have a diagram or a harness they could take a pic of??
