Old 03-20-2013, 01:52 PM   #1
jhiggy94
Trailer Brakes
Has anyone wired up a trailer brake system in a 72? I've never wired anything like this up before and any help would really be appreciated. Do I have to run new wires all the way up from the trailer brake unit? Is there a better unit to use than any others? Thanks guys
jhiggy94 is offline   Reply With Quote
Old 03-20-2013, 04:02 PM   #2
jasons
not enough hours in the day
jasons's Avatar
Re: Trailer Brakes
This is the controller I've installed in all my vehicles. It has an adjustable output without the fancy display. http://www.tekonsha.com/content/prod...1435&part=9030
It is a 4 wire hookup. Power, ground, output from brake light switch and feed wire that goes to the trailer plug. The last wire is the only one that needs to be run outside the passenger compartment.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 03-20-2013, 08:11 PM   #3
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Re: Trailer Brakes
I have a Hayes G2 Brake Boss in my truck
http://www.hayesbc.com/?page_id=1045
Since you're wiring brakes, I assume you either already have or are adding a 7-way trailer connector? There should be a 12v positive feed (20A self-resetting breaker) to the connector as well to supply the breakaway system with power.
I chose to run the trailer harness ground into the cab as well (I attached it to the parking brake bracket) to protect it from the weather and ensure my trailer brakes have a good clean ground source.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
