Old 03-21-2013, 12:03 AM   #1
chev-obsession
chev-obsession's Avatar
6 lug disc conversion, wheel backspacing
I've converted my 65 1/2 ton using baer brakes kit, lowered 2.5" in the front using mcgaughy's drop spindle and 5'' (I think) in the rear with a spring. I threw a set of wheels off of a newer chevy avalanche and it looks like the wheels in the front stick out about 2'' past the back wheels. I've searched and found some rotors that offered different spacing, but that's not an option for me.
Is this is a common issue when lowering these trucks or is it the wheels? as far I know the wheels on the truck are the same back spacing now.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 03-21-2013, 12:49 AM   #2
Slow Build
Slow Build's Avatar
Re: 6 lug disc conversion, wheel backspacing
Most dropped spindles move your front wheels out 3/4" per side. I don't know if the bigger brakes effect the offset.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-21-2013, 12:49 AM   #3
pestwagon
yes it is. I just used McGaughneys 2 1/2 " drop spindals, stock front springs with 3 " rear coils . I run 15 x 7 front slotted mags and 15 x 81/2 rear slots and they balance out to look even from the side. The rotors in the front tend to push out the front wheels a bit, they claim only 1/4 inch or so, but to me it looks like a bit more...
pestwagon is offline   Reply With Quote
Old 03-21-2013, 01:07 AM   #4
HugoV
Subscribed
HugoV is offline   Reply With Quote
Old 03-21-2013, 10:33 PM   #5
chev-obsession
So, to fix my problem... Can I get away without using wheel spacers and get wheels with a different offset or what?
1965 c/10 swb
1969 c/10 lwb
Old 03-21-2013, 11:27 PM   #6
Rich 5150 69
Rich 5150 69's Avatar
The front to rear track width is differant, the rear axle on the 65, is in fact almost two inches narrower that the front, in 1971 GM changed the rear axle track width by 1.5 inches, so if this really bothers you, you have two choises, buy wider rims for the rear or differant back spacing or change out the rear axle to a `71 or newer..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-22-2013, 12:07 AM   #7
chev-obsession
I totally forgot about the front being wider.... that explains it. hanks for the info, ill see if ican get some different wheels
1965 c/10 swb
1969 c/10 lwb
