Old 03-20-2013, 05:56 PM   #1
nitrosport_5
nitrosport_5's Avatar
WTB: Dual Horns High and Low
Im looking to buy a set of dual horns. I have the factory harness, but no horns. I have a second dual horn harness as well id be willing to sell or trade. Let me know what youve got.
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 03-20-2013, 06:02 PM   #2
cypressbog
Go Pack Go!
Re: WTB: Dual Horns High and Low
I've got a set, tested individually but no harness to hear both. Will sell for $25 plus the ride. Can get a pic tonight.
cypressbog is offline   Reply With Quote
Old 03-20-2013, 06:05 PM   #3
nitrosport_5
I'm interested. you can post here or email pics to nitrosport_5@Hotmail.com
Old 03-20-2013, 08:54 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
I pulled a few parts off a 72 highlander in a local yard, including the dual horns and harness, then decided I wood buy he whole core support, so I left he horns on it. They pulled it for me but when I went back to pick it up, one of the horns was gone (!) and they don't know what happened to it. Nice.
Does anyone know the background on the dual horns, was it an option shown on the spid label, or part of another package, or what? I know most of the Cheyennes I have seen had them, and this highlander did as well. I am going back tomorrow to see if I can find the second horn. I don't know if it was the high or low note one. I think it was the one nearest the fender. Does anyone know if it was the high or low note in this spot?
Would a truck with one horn have the high or low note horn?
My luck is the horn they left is the same as what I already have and they lost the one I need.
WIDESIDE72 is offline   Reply With Quote
Old 03-21-2013, 10:20 AM   #5
rockc
I have a couple horns; but how can you tell the Low from the High?
Rock C
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 03-21-2013, 10:27 AM   #6
WETOWM
the high note will have a :H : stamped on it the low will have no stamp
WETOWM is offline   Reply With Quote
Old 03-21-2013, 12:19 PM   #7
cypressbog
Go Pack Go!
I found my crusty set I pulled off a WI truck, not sure if they work. I can't find the good set I bought some years ago. Sorry.
Old 03-21-2013, 01:25 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
I would be interested in a pair of working horns after nitro sport finds his.
Old 03-21-2013, 05:27 PM   #9
nitrosport_5
could you test em? thanks for looking
still looking for a set for now!
Old 03-21-2013, 09:53 PM   #10
cypressbog
Go Pack Go!
K, charged battery on truck, tested each. One didn't work, other sounded really sick. Guess they go to the scrap pile. I also spent some time looking thru my good parts and can't for the life of me find the good ones.
Old 03-21-2013, 10:09 PM   #11
GMCNUT
GMCNUT's Avatar
[QUOTE=WIDESIDE72;5960268]
I just took a set of these off a 1970 CST I found at the salvage yard to put on my own 70 CST, and they were listed on the Spid label as a separate "dual horns" option....I thought it was really cool because I never knew there was an option like that before I read the label and then went under the hood to find them. Nice little green jumper harness between them too....pretty neat
GMCNUT is offline   Reply With Quote
Old 03-22-2013, 01:52 PM   #12
nitrosport_5
i appreciate you looking and testing the horns you have.
Still in need of a set if anyone else has a set!
Old 03-22-2013, 01:58 PM   #13
Oddfire
Oddfire's Avatar
I believe the one nearest the fender is the lo.
Oddfire is offline   Reply With Quote
Old 03-22-2013, 08:19 PM   #14
Tbruz
Nitrosport
Interested in your spare harness.
How much you looking to get?
Thanks,
Tbruz
Tbruz is offline   Reply With Quote
Old 03-24-2013, 02:47 AM   #15
nitrosport_5
Originally Posted by Tbruz View Post
Nitrosport
Thanks,
Tbruz
not sure. what's it worth?
bump still looking
Old 03-24-2013, 02:56 AM   #16
WIDESIDE72
WIDESIDE72's Avatar
I went back to the yard today to pull some more stuff and found the other horn. It has a "H" on it! I already got the jumper wire and the rad support had the low note horn on it still. Now to see if they work! I also found another high not horn in my junk. The bracket on it is not quite the same. I plan to test it as well.
Old 03-24-2013, 02:58 AM   #17
nitrosport_5
want to sell the pair? :-D
Old 03-24-2013, 11:14 AM   #18
WIDESIDE72
WIDESIDE72's Avatar
Want to gamble on buying a pair of untested horns? Haha
Old 03-24-2013, 11:30 AM   #19
sasquatch58
how much for the duel horn harness
sasquatch58 is offline   Reply With Quote
Old 03-24-2013, 02:28 PM   #20
WIDESIDE72
WIDESIDE72's Avatar
How badly do you want dual horns?
i had a 71 El Camino in high school (years ago) and if I remember correctly they are the same, just need the bracket bent to fit the 67-72 trucks.
http://www.ss396.com/mm5/merchant.mv...ct_Code=ADR-3H
http://www.ss396.com/mm5/merchant.mv...uct_Code=27730
Old 03-24-2013, 04:00 PM   #21
Tbruz
Its your part Nitrosport,
Don't want to insult anyone, you set the price you'd like to get for it.
Tbruz
Old 03-25-2013, 01:29 PM   #22
70STOVEBOLT
70STOVEBOLT's Avatar
Steve, if the extra hi note horn you have works, I will take it. Let me know.
Thanks,
Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-25-2013, 02:18 PM   #23
turp mcspray
turp mcspray's Avatar
FYI...non working, and sick sounding horns, will usually be fine if you spray a bunch of wd-40, or something similar inside and let soak awhile.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 03-25-2013, 03:46 PM   #24
70STOVEBOLT
I'll give it a try, thanks.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 04-09-2013, 02:01 AM   #25
nitrosport_5
Bump, still looking
