Old 03-22-2013, 04:24 PM   #1
Tukn22z
Control arm shaft centering tolerances
So i installed new bushings and shafts in my upper control arms and as far as the shafts being centered, one control arm was off .070" and the other was .072" off center. what i did was indicate each shaft hole and used an edge finder and bumped up to the side of the arm. Is this something to be concerned about? I really dont want to take these apart again.
Tukn22z is offline   Reply With Quote
Old 03-22-2013, 04:40 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Control arm shaft centering tolerances
To make sure the measurements are correct... it is .072" as in less than 1/8" correct? Not .72" as in almost 3/4"?
If it is only .072" and .070" you should not worry about it. That's probably a tighter tolerance than 99% of them came with from the factory.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-22-2013, 04:46 PM   #3
Tukn22z
yea that's correct .070 thousandths, thanks for answer I appreciate it.
Old 03-22-2013, 05:18 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
No worries... these trucks came with over a 1/2" tolerance from the factory. It will drive guys like us CRAZY!!!!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
