Old 03-22-2013, 02:50 PM   #1
cjj737
Angry Question / Help
I have 67 C10 LWB 250 CI.
The other day i was looking at my engine and ujust happened to grab my fan and give it a lil wiggle back and forth in direction of rotation. To my suprise it moved about half an inch in each direction. My guess is that the crank key has sheered and is alowing it to rotate.
Any suggestions.
cjj737 is offline   Reply With Quote
Old 03-22-2013, 03:16 PM   #2
Davemotohead
Davemotohead's Avatar
Re: Question / Help
Think your fan hooks to your water pump and not the crank? It will also spin as the fan belt will slip.
edited by staff
Davemotohead is offline   Reply With Quote
Old 03-22-2013, 03:39 PM   #3
cdowns
cdowns's Avatar
Re: Question / Help
maybe buy yourself a service manual with pictures
Old 03-22-2013, 04:23 PM   #4
cjj737
Re: Question / Help
i do understand that the fan will spin but. the crank pully moves when i move the fan and yes i know the fan is connected to the water pump.
Old 03-22-2013, 04:29 PM   #5
Davemotohead
Re: Question / Help
sometimes you can turn the entire crank easy if the fan grabs the belt,I often turn my crank by grabing the fan belt and giving it a pull, pull off the pully if you think the keyway is bad and check?
edited by staff
Old 03-22-2013, 04:33 PM   #6
cjj737
Re: Question / Help
My guess is keyway i can move it with one finger.
Old 03-22-2013, 04:36 PM   #7
Davemotohead
Re: Question / Help
Take the Pully bolt out and then look at the crank when you spin the pully and see if its spinning on the crank?
edited by staff
Old 03-22-2013, 04:50 PM   #8
haysonj
haysonj's Avatar
Re: Question / Help
If is is spinning on the crank your alt light would be on and more than likely it would be over heating
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-22-2013, 04:59 PM   #9
faribran
Re: Question / Help
there is no pulley bolt unless someone has drilled and tapped it... sounds like something is not quite right...
faribran is offline   Reply With Quote
Old 03-22-2013, 05:10 PM   #10
hyatt
Re: Question / Help
I have seen what you are talking about before When you remove balancer keyway in crank will probally be bad Balancer will probally come off with your hands If crank is tapped for a bolt epoxie a new key in crank and replace balancer If not tapped see if you can tap it for a bolt Otherwise you will have to replace crankshaft The only other alternative (and not a proper fix)is to spot weld balancer to crank to get you by until you can pull engine and fix it right
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 03-22-2013, 05:13 PM   #11
cjj737
Re: Question / Help
my volt meter is still registering volts and it has not died yet.
Faribran there is a bolt in the crank pully not sure when it was put in. i picked up the truck last july.
Old 03-22-2013, 05:25 PM   #12
haysonj
haysonj's Avatar
Re: Question / Help
That is probably why someone put the bolt in because the snout on the crank is worn. You could be lucky and the inside of the dampner is what is worn
Old 04-15-2013, 03:03 PM   #13
cjj737
Re: Question / Help
Any suggestions.
so sunday i decided to change water pump and hoses. and find out why my balancer rotates a half an inch each direction. this is what i found..
Old 04-15-2013, 03:12 PM   #14
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Question / Help
Yep.... that would do it, it should have been leaking alot of oil as well the seal has grooved the snot out of it.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-15-2013, 04:03 PM   #15
cjj737
Re: Question / Help
oh yes she was covered in caked on oil i was putting about a quart a week in.
Old 04-15-2013, 04:08 PM   #16
cjj737
Re: Question / Help
so can this crank be save any thoughts
Old 04-15-2013, 05:20 PM   #17
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Question / Help
The crank needs to be repaired which means the crank has to come out of the engine and be welded and repaired by a machinist.
If you put a new balancer on that crank without repairing it, the same thing will happen again.
From the photo you posted, it already looks like someone tried to do a "get by for now" repair.
TBONE1964 is offline   Reply With Quote
Old 04-15-2013, 05:51 PM   #18
Ol Blue K20
Re: Question / Help
That keyway looks to be wollered out. It also looks like someone tryed to peen it with a centerpunch to tighten things up. I hate to say it.. pull it out and get a crank or have that one repaired
Dale
Old 04-15-2013, 08:42 PM   #19
cjj737
Re: Question / Help
yeah thats what i might have to do but not sure if a machine shop can fix that.???
also thinking of getting a rebuild one to drop in place but being active duty navy kind of hard on the pocket...
