Old 03-23-2013, 12:41 PM   #26
Space Monkey
Re: Newb to forum w/ 82 gmc C1500
So I'm guessing if the plug is black and reeks of gasoline it's probably fouled?
Will be replacing the plugs today. Any brand/material preferences you guys have?
Space Monkey is offline   Reply With Quote
Old 03-23-2013, 12:50 PM   #27
Space Monkey
Originally Posted by bilfman View Post
With the popping sounds like timing, these things rarely foul enough plugs not to run. Take no. 1 cylinder to tdc compression stroke, then pull your cap and make sure it is pointing to no. 1 Cylinder on your cap. That is what I would check first .
Am I checking that the rotor is pointing to 1?
Old 03-23-2013, 01:15 PM   #28
Restrorob
The One And Only !!!
Restrorob's Avatar
Yep..... And having been in the auto biz, I've seen many fouled plugs prevent a engine from starting..... AC R45TS is the most common used.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-23-2013, 02:34 PM   #29
bucannon
Salty Sailor
bucannon's Avatar
Lets see some more pictures of this truck!
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 03-23-2013, 11:31 PM   #30
Space Monkey
Fixed!
So, super newb mistake, the choke on my carb was stuck closed. I had no idea what I was looking for so I didn't know. lol. Had a friend, who is the Chevrolet wizard, fix it, and fix my timing. Runs like a champ.
Pics tomorrow.
Old 03-24-2013, 09:03 AM   #31
Space Monkey
Got it out on the road and ran it a little bit today. Seems like it's running a little warm and when I shift into 3rd and get on it it spits once and then goes. Same way every time. I'm guessing I need to tune my carb a little more?
Edit - The warmth idk.
Old 03-24-2013, 10:57 AM   #32
bilfman
bilfman's Avatar
Congrats on getting it rolling! Now post a burnout pic
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-26-2013, 01:04 AM   #33
Space Monkey
As soon as I fix the flat I just got... Grrr.
So my truck came with Hooker headers but they're pinched on the driver's side, probably from the same bottom out that broke the front drive shaft, and I'm not real thrilled about the fitment. Thinking about going back to stock headers.
What do yall think about the stock headers vs. aftermarket?
Old 03-26-2013, 05:53 AM   #34
Space Monkey
Additional question to whom it may concern - When I bought the truck the previous owner told me he had not checked the second fuel tank and didn't know if it leaked. I took that to mean he knew it was leaking. How do I check if it's leaking other than just putting gas in it?
Old 03-26-2013, 12:12 PM   #35
Space Monkey
Bump?
Sorry to bombard you guys with so many questions, I just want to fix this dang truck.
