Old 03-23-2013, 06:12 PM   #1
Woogeroo
Question 1964-1966 trucks - rear sway bars with coil springs?
Howdy folks,
I'm just curious about this and how it sets up on our trucks with the rear coil springs.
Do any of you have any experience with this?
Have any good links to tech articles or photos?
I'm just curious as to how it is setup and works with the coil springs and trailing arms.
Thanks.
-W
Woogeroo is offline   Reply With Quote
Old 03-23-2013, 06:54 PM   #2
Trsmotrhed
Trsmotrhed's Avatar
Re: 1964-1966 trucks - rear sway bars with coil springs?
I just installed one from CPP.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 03-23-2013, 09:37 PM   #3
Woogeroo
Ah... it has brackets on the frame rail, then brackets/bolts on the trailing arm itself.
Interesting...
Thanks for sharing Trsmotrhed.
-W
Old 03-23-2013, 09:58 PM   #4
Trsmotrhed
Trsmotrhed's Avatar
Interesting...
-W
You're welcome. I just finished Sunday and left town. Haven't drove it yet to see the difference. Snow and ice since I've been home.
63 SWB C10
Old 03-23-2013, 10:26 PM   #5
CRGRS 66
CRGRS 66's Avatar
Would be very interested to hear some feedback on how the CPP bar works for you. I have the same bar, but have only mocked it up prior to stripping off the rear suspension (frame going out to be blasted and painted soon)
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 03-23-2013, 11:23 PM   #6
RockTonka
RockTonka's Avatar
We chased down a rear sway bar from a 84 Camaro (junk yard) and flipped it upside down and backwards to work in our burb...works great and it was cheap!
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is online now   Reply With Quote
Old 03-24-2013, 12:56 AM   #7
Woogeroo
Thumbs up Re: 1964-1966 trucks - rear sway bars with coil springs?
RockTonka - I've read various mentions of using that era of rear sway bar on our trucks, but always wondered exactly how it attached.
Thanks for sharing the photos!
-W
Old 03-24-2013, 01:13 AM   #8
Trsmotrhed
Trsmotrhed's Avatar
That looks great. I didn't know you could use a camaro sway bar.
63 SWB C10
Old 03-24-2013, 01:47 AM   #9
Snowbound
Snowbound's Avatar
What is the diameter of the Camaro bar? I found one at the yard but it was very tiny. Did not measure but was less than 1".
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 03-24-2013, 03:09 AM   #10
RockTonka
RockTonka's Avatar
7/8" on the rear swaybar, we have a 1 1/4" bar on the front from a dually...overall it feels very well balanced.
My build thread
Old 03-24-2013, 09:30 AM   #11
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
the camaro/firebird bars come in various diameters. I think they range between 15-24 mm (≈5/8 - ≈15/16) You don't need as big a bar on the rear as you do up front
http://www.low69cst.freeservers.com/CamaroBar.htm
Larry
fleetsidelarry is offline   Reply With Quote
Old 03-24-2013, 09:47 AM   #12
rideblue00
rideblue00's Avatar
So what exactly is it supposed to do for the rear? I havent done any reading on this subject yet.
rideblue00 is offline   Reply With Quote
Old 03-24-2013, 09:51 AM   #13
Reyals Bemus
I will be installing a 1" Camaro sway bar pretty soon. I will be mounting it underneath the axle instead of on top like RockTonka did. My truck is lowered.
Will come back and post pictures.
Reyals Bemus is offline   Reply With Quote
Old 05-01-2013, 04:48 AM   #14
Woogeroo
Anyone else have anything to share?
-W
Old 05-01-2013, 07:52 AM   #15
fleetsidelarry
Senior Car Nut
Woog, another member whose name I can't think of at the moment (imagine that), used the Camaro bar but moved it so that it attached to the trailing arms and frame sort of like the aftermarket one in the 1st response. I was thinking that the thread was in your faq section, but, again can't remember for sure
should be searchable cause I saw it not long ago (less than a year), I'll see if I can find it after I've had enough coffee
edit: losthope may be who I'm thinking of
http://67-72chevytrucks.com/vboard/s...4&postcount=76
Larry
Old 05-01-2013, 08:40 AM   #16
fleetsidelarry
Senior Car Nut
found it:
http://67-72chevytrucks.com/vboard/s...&postcount=241
Larry
Old 05-01-2013, 10:17 AM   #17
T Smith
T Smith's Avatar
I just installed the bar from Brothers which is an Addco bar repackaged and is just like the CPP and POL bars. I chose it because they had it on sale for $100. The handling is much improved but I don't like the way it mounts below the trailing arms, makes it kinda stick out like a sore thumb from the side view. I really like the Camaro bar being tucked up above the trailing arms and out of sight.
T Smith is offline   Reply With Quote
Old 05-02-2013, 09:20 AM   #18
fleetsidelarry
Senior Car Nut
good info, T Smith, thanks
Larry
Old 05-02-2013, 11:22 AM   #19
vin63
It's Better With Nitro
vin63's Avatar
-W
I didn't have enough room to run a traditional sway bar, so I used a through-frame torsion bar...plus the tubular housing helped with mounting my fuel tank and electric pump.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-21-2013, 07:26 PM   #20
Woogeroo
vin63,
my, what a nice frame you have.
-W
Old 05-21-2013, 08:03 PM   #21
ol_skool_chevy
ol_skool_chevy's Avatar
Thats the same one I used...i love it ,,and CHEAP. i think i paid 20 bucks
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 09-27-2014, 06:53 AM   #22
Woogeroo
I wandered into this company site awhile back :
Hotchkis Sport Suspension
They have some options for rear anti-sway setups... among other suspension components for our '63-'66 trucks.
They also have other options for the later model chevy trucks.
Anyone have more information to add to the pile?
-W
Old 09-27-2014, 09:07 AM   #23
Clyde65
Clyde65's Avatar
Woog, those are some seriously nice options from Hotchkis, I dont know if my budget would allow but they are nice!
I like the Camaro, just for price and it seems to work for those that have it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-27-2014, 10:48 AM   #24
chevyrestoguy
chevyrestoguy's Avatar
With the Camaro sway bar mounted like Rock Tonka did, I wonder if there is room to snake a pair of tailpipes past it?
I love the idea of using a factory Camaro bar, and the price is almost too cheap to pass on.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-27-2014, 09:58 PM   #25
Woogeroo
Wink Re: 1964-1966 trucks - rear sway bars with coil springs?
Yep, they are very nice... but more for folks that race on the touring type road courses I'm guessing. I just happened to come across them and saw that they had bits and pieces for our '63-'66 trucks.
Anything that is safe and works is the sort of thing that I am looking for in this thread.
-W
