Old 03-23-2013, 11:57 PM   #1
Space Monkey
Intake spacer question
So I have an aftermarket (Weiand) INTAKE with a spacer on it. The issue I'm having is that the spacer puts my throttle cable at an awkward angle which makes my gas peddle go from nothing to everything in a hurry. This is a problem with my 4 speed manual.
So, do any of you guys know of anyone that makes a bracket to raise the position of the throttle cable? Something that will go around the back of the carb just to lift it a little?
Have any of you guys encountered this problem? Here's a pic of my throttle cable -
Space Monkey is offline   Reply With Quote
Old 03-24-2013, 12:01 AM   #2
78maliburat
Re: Intake spacer question
use some longer bolts with flat washers on the bottom
78maliburat is offline   Reply With Quote
Old 03-24-2013, 12:06 AM   #3
Space Monkey
Can you break it down like a fraction for me? Longer bolts where with flat washers on the bottom of what?
I'm sorry, I'm super new at all this and learning as I go.
Old 03-24-2013, 01:25 AM   #4
78maliburat
The bracket has bolts that mount it too intake remove them and get longer bolts and stack flat washers between bottom of bracket ind intake ............washers serve as a spacer tom raise it up off the intake
Old 03-24-2013, 01:37 AM   #5
Space Monkey
Ha! Ok, perfect. I will try that. Thank you sir.
Old 03-24-2013, 02:17 AM   #6
Redcap
Get the other throttle bracket. Your local parts store should have one.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 03-24-2013, 02:39 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
In your pic you have the transmission cable bracket and not the upper throttle bracket
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-24-2013, 08:46 AM   #8
Space Monkey
oh... well that would probably explain it. lol.
Old 03-24-2013, 09:48 AM   #9
mrolds88
I'm with Redcap. Get a bracket. Factory used one that bolted to the carb base. See what the auto parts store has and maybe a trip to the salvage yard.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-24-2013, 10:23 AM   #10
88Jimmy4x4
88Jimmy4x4's Avatar
exactly, you need the bracket that attaches to carb, spacer height wont matter then
http://www.ebay.com/itm/SBC-Q-Jet-th...f39ce8&vxp=mtr
heres a pic of mine
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 03-24-2013, 03:55 PM   #11
Space Monkey
The qjet one work with my edelbrock?
Old 03-24-2013, 10:01 PM   #12
Space Monkey
Fixed. Part right off the shelf at O'reilly's.
Thanks, you guys are awesome.
