Old 03-24-2013, 10:20 PM   #1
heathbirkendahl
Plug and Play LED's
Anyone use these LED's and get them to work?
Mine work until I turn my headlights on. Then no blinkers.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 03-24-2013, 11:34 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Plug and Play LED's
I am going to give them a shot too. I'll let you know if I have a similar outcome. I wish us both luck..
Just for grins, check your grounds.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 03-25-2013, 09:54 AM   #3
67Slider
67Slider's Avatar
I had the same problem with my wife's 66 mustang. Never could get the damn things sorted out. Ended up sending them back and getting a refund. I tried different no-load flashers, cleaning grounds and all kinds of other crap. No luck.
Hope you get it sorted. Just a note. They weren't from the same vendor that is advertising on this board.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 03-25-2013, 11:22 AM   #4
heathbirkendahl
Here's the pic again.
Old 03-25-2013, 11:23 AM   #5
74baggedbug
Dang I'd like some for my 68!!! Where did you get them from? Thanks
74baggedbug is offline   Reply With Quote
Old 03-25-2013, 11:33 AM   #6
heathbirkendahl
LMC truck. But let me see if I can get them to work first. They are not working correctly. When I turn on my headlight they won't flash.
Old 03-25-2013, 12:34 PM   #7
LEX
LEX's Avatar
Don't you have to swap to an electronic flasher?
LEX is offline   Reply With Quote
Old 03-25-2013, 12:47 PM   #8
heathbirkendahl
I thought you did not with these. But, I could be wrong.
Old 03-25-2013, 01:52 PM   #9
b.eddy's72
b.eddy's72's Avatar
LED lights dont not pull as much current as a regular bulb therefore the flasher does need to be changed to flash properly unless the set up has a bult in resistor to draw more current. I had LED's on my motorcycle and had to add resistance because they blinked REALLY fast. LED's also have a polarity that must be followed. Current only runs through them one direction as with most diodes (LED- Light Emmitting Diode) Good luck
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 03-25-2013, 02:26 PM   #10
71chevydude
The rear LED lights I got you have to buy the electronic flasher to make them work properly
71chevydude is offline   Reply With Quote
Old 03-25-2013, 02:27 PM   #11
heathbirkendahl
I have the rears (plug and play type) and they work fine. But maybe the combined front and rear change that.
BUT, they work fine until I turn the head lights on. They don't flash at all.
