03-22-2013, 06:38 PM | #1501 |
Re: Finally starting my Longhorn 4x4 conversion
you might as whell use the bottom of the hitch assembly as the top mounts of the bags it should hold just fine and you can hide the airlines only the exaust might be in the way , i see you allready have some boxsection welded in there to fill the gap for the hitch setup and it looks like it would place the bags pretty close to the leafsprings
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
03-22-2013, 09:32 PM | #1502 |
Leaf springs, we dont need no leaf springs.
i have a hunch that Ryan has some bracketry to 4 link his truck and eliminate the current springs entirely and get them bags out wide enough to promote good stability. |
03-23-2013, 12:56 AM | #1503 |
Ive seen picture proof of the brackets!
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
03-24-2013, 08:48 PM | #1504 |
6>8 Plugless........
I got some more done yesterday. I removed the old rear cross member, welded in the new, and removed the rest of my tank cross members. I then welded up all the un used holes from the goose neck back. Next I'll replace the last OEM cross member and then remove the stock suspension.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-24-2013, 09:48 PM | #1505 |
Its all downhill from there....
03-24-2013, 11:28 PM | #1506 |
Hi Ryan. Whats your hyd clutch exerience? Im abt to mount my master cyl and dont like the oem dodge 1/4 turn master. I will use the getrag slave but was hopin 4 something with a little better mount than the oem dodge master. Any thoughts ?
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
03-25-2013, 12:24 AM | #1507 |
Junk Yartist
Maybe I will convince my brother he needs to box his crew cab frame... and have someone else do it
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
03-25-2013, 09:15 AM | #1508 |
You could use a Ford master and Dodge slave, but there is a little bit of adapting that will go on. What exactly dont you like about the 1/4 turn master? Aftermarket 3rd gen use a bracket that bolts to the firewall.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
03-25-2013, 03:12 PM | #1509 |
The 3rd gen still twist into the bracket. We've only had one truck have issues with the master cylinder popping out out of many. You can use a 94-97 ford f-250 and 350 master and line on a dodge slave and it'll work fine. The ford master bolts on to the firewall.
03-25-2013, 03:14 PM | #1510 |
Here are a couple other pictures from Saturday.
03-25-2013, 03:25 PM | #1511 |
high-Tech Red Neck
So wheres the fuel tank gonna go?
"He used to be a pretty nice feller, now he's a welder!" |
03-25-2013, 05:11 PM | #1512 | |
03-25-2013, 06:23 PM | #1513 |
It's going to go in between the goose neck hitch and the rear cross member. The 40 gal burb tank I have fits in there pretty good. I'll take pics of that when I get it back in there.
03-25-2013, 06:37 PM | #1514 | |
Thanks again .
03-25-2013, 08:44 PM | #1515 |
Right where all the exhaust is going to try and go...
03-25-2013, 09:44 PM | #1516 |
Junk Yartist
I thought he said something about one of those contraptions on the front that eats small cars struggling with a Yakima roof carrier and turns them into fuel.
03-26-2013, 08:06 PM | #1517 |
I removed the last stock cross member today and welded in the new. Now I have to remove the rear suspension, and get welding holes up. Then it'll be on to boxing the frame and getting the 4 link brackets placed and welded on.
03-26-2013, 08:08 PM | #1518 |
Yep, pretty much sums it up. Exhaust routing is going to be fun. The easy way would be a stack, but IDK if I really want to go that route at the moment.
It fits in there pretty nice. I need to get the frame boxed, set the bed on, and see how much room I don't have above the frame first.
03-26-2013, 08:26 PM | #1519 |
You dont have, pretty much any... the bedfloor supports are at the top of the frame. if you want to notch them you could have some room.
03-26-2013, 08:27 PM | #1520 |
03-26-2013, 09:32 PM | #1521 |
lo0ks great so far
Truck: 1972 International Harvester 1210 Engine: Caterpiller 3116 220 HP 630 tq Transmission: Eaton Fuller rt 6610 Axles: Merritor I beam front axle |
03-26-2013, 10:35 PM | #1522 |
03-26-2013, 10:36 PM | #1523 | |
03-26-2013, 10:55 PM | #1524 |
mine stalled, got a new job and dont have the time yet, i have all the parts, just need to install it
03-26-2013, 11:48 PM | #1525 |
You should go with the regular exhaust, I dont think a stack or dual stacks would look good on that truck. plus it will be cleaner for the truck an any trailer that you haul.
1984 chevy K20 in the works 1992 F350 cummins swap 1999 F350 powerstroke |
