#151 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: 72 K20 Cheyenne Super Build
Thanks guys!
Did this truck come with one of those charcoal canisters mounted under the hood to vent the gas tank? If so, anyone have some detailed pics to help me out?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#152 |
'72 3/4 ton and up should not have had a charcoal canister, at least for Federal emissions, California emissions I am not certain.
#153 |
Carpe manana
That's helpful and may explain why there wasn't one under the hood. Thanks. Pete
#154 |
Wow, I'm not sure how you hid this build from me
#155 |
![]() Join Date: Aug 2010
Any pictures with the wheels/tires on? I need motivation
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
#156 |
Carpe manana
Man I'd love to have those on right now and Eric the shop manager knows that. He has a good point for holding off though as they could be stepped on to reach areas in the bed etc. and get scuffed up. So for now we are holding off. Stay tuned!
#157 |
Carpe manana
I did scare up this NOS period correct 23 channel CB for $20 shipped!
#158 |
Breaker Breaker we got us a CONVOY!
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#159 |
Carpe manana
#160 |
Carpe manana
Scared up a NOS engine timing tab to swap out with the now orange OEM piece - thanks for the feedback. Went with a standard HEI distributor rather than a small body type: wanted to avoid use of a coil.
Trim going on. A combo of Mar-K upper and NOS wood grain lower. I went with all metal clips for the trim attachment rather than a combo of metal and adhesive. GM NOS vent shades and door handles are in place.
#161 |
Carpe manana
NOS cab divider trim....those guys are doing a kick a%% job
#162 |
Man of Mini-Talents
Man oh man, does that look good! I love this part of the build when you finally get rewards for all the hours of labor.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#163 |
Carpe manana
Need help with this install fellas. This is an OEM Blazer skid plate. The cross member is supposedly correct for the skid plate but you can see there's a crazy gap between the plate and its cross member. Is that a correct cross member or were spacers used in the installation of the plates on a Blazer? I suspect I was sold an incorrect cross member - hope the frame holes align with a correct member.
First pic is mine second a borrowed pic of an installed plate.
#164 |
Chevy Enthusiast
Can you swap the two members, it looks like your front one is longer.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#165 |
Carpe manana
I think what I'll have to do is scare up an auto tranny crossmember and use that. I'm told that a skid plate xmember is the same as the auto tranny xmember minus the riveted brackets.
#166 |
Head north Pete! i have one in the garage.
Ryan |
#167 |
Carpe manana
#168 |
let me know if you want it, ill try to box it up
Ryan |
#169 |
it seems that you aready have a auto tranny x member with out the riveted brackets.... i would put some nice spacers in there and be done.
#170 |
Carpe manana
Not a bad thought....we tried that actually but it looked too funky for my taste...kinda like a 6" blocks under leaf spring lift look
#171 |
Carpe manana
Missed the post earlier....thanks bud! Appreciate you keeping up with the build. Pete
#172 |
Very clean prject and awesome. Subscribed!
email me @ nasser_060@hotmail.com and Check out my flicker @ http://www.flickr.com/photos/0060/ |
#173 |
By the way, I m looking for this rubber between the finder and the door for my chevy 1984.
Where did you get it? [IMG] ![]() Posted via Mobile Device
#174 | ||
Carpe manana
#175 |
Second Chance Program
This is about the fastest resto i have ever seen!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
