Old 03-25-2013, 11:47 PM   #1
LSUMurse
LSUMurse's Avatar
Growling noise from steering pump
I recently put power steering in the truck, holy crap what a difference!
However, if I start the truck when it's cold outside, the pump makes a growling/grinding noise. It stops making noise once the engine has warmed up and doesn't make any noise at all if it's warm outside when I start the truck. It's been on for about a month, so I don't think it needs any further bleeding. It's not low on fluid. It was a junkyard pump from a '76 and the gear is from an '81 so I switched the high pressure outlet to accomodate the metric thread gear line.
What do y'all think? Get a rebuilt one? Is there something I can trouble shoot?
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 03-25-2013, 11:56 PM   #2
buckskins4ever
buckskins4ever's Avatar
Re: Growling noise from steering pump
you sure the fluid is still full? I had this happen when replacing a pump. Once I had did the steering wheel type bleeding, it had sucked down enough to run it low. Unless there could be some metal in the pump gear housing.
buckskins4ever is offline   Reply With Quote
Old 03-26-2013, 12:04 AM   #3
LSUMurse
LSUMurse's Avatar
I'll check again when I get home. I checked after I did the initial bleeding and it was full. At least that would be an easy fix. It seems weird how it stops when it warms up. Would the fluid expand that much?
Old 03-26-2013, 08:32 AM   #4
CC69Rat
CC69Rat's Avatar
Could have a crawfish stuck in it or something ..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-26-2013, 09:19 AM   #5
LSUMurse
LSUMurse's Avatar
It is the season, and I do like them HOT!!
Old 03-26-2013, 10:29 AM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I would also run some Lucas Power steering conditioner in the fluid, It may have a little air still in it and by the time it gets warm it has found a high spot.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-26-2013, 10:56 AM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I will bet it is low on fluid.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-26-2013, 11:22 AM   #8
cdowns
cdowns's Avatar
is the belt tight enough?
Old 03-26-2013, 11:35 AM   #9
oklalawnboy
oklalawnboy's Avatar
This is my idea too. When the engine is cold everythings a little harder to turn making the belt slip. Plus the alt is charging harder after sitting all night and making the belt slip if not good and tight.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
