Old 03-26-2013, 11:32 AM   #1
FOSTER21
School me on the Porterbuilt drop members.
I'm new to this low and shiny stuff, what are the benefits to the Porterbuilt stuff? What does each style get u and what are the heights
FOSTER21 is offline   Reply With Quote
Old 03-26-2013, 12:06 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: School me on the Porterbuilt drop members.
Welcome to the board!
Do some reading over here:
http://www.porterbuiltfabrication.com/
Keith
Convert to disc brakes.
Old 03-26-2013, 12:08 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum FOSTER21. Please offer more specific details on what your looking for? There is a LOT of DM equipped trucks on this forum that would be glad to share info. Help us help you.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-26-2013, 12:11 PM   #4
Pro Performance
Pro Performance's Avatar
Welcome to the forum!
Some of the main benefits to the dropmembers is being able to get lower since everything is tucked up higher. You will also get rack & pinion steering, wheels moved forward 1" and a narrowed track width.... as well as overall better suspension geometry. Did I mention they look cool and get you to lay frame! lol
The Mild crossmember is raised 1" higher over factory, the touring is raised 2" and the extreme is raised 3" higher. Which one to go with all depends on size if tires you are wanting to run and how low you want to go. Some guys will go with the Mild being they don't want to quite lay frame, but want all the other benefits of the dropmember. Where the guys wanting to lay frame and have a really low ride height will go with the extreme setup.
I believe I covered the main points here, but feel free to call and can go over in further detail. Can also determine what your plans are for the truck and which one might work best for you.
I am sure Nate will chime in and shed some light on this also.
- Travis
Pro Performance is offline   Reply With Quote
Old 03-26-2013, 12:38 PM   #5
jimmydean
jimmydean's Avatar
Delmo and others posted some good stuff in the Dropmember thread, too.
http://67-72chevytrucks.com/vboard/s...d.php?t=564415
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-26-2013, 01:38 PM   #6
FOSTER21
Thanks guy's. I'm trying to buy a 68 chevy swb if the guy can find the title. I plan on a 19" CCW SP500 wheel. Just looking to get it low and still ride great. I've had enough of the lowerd F-body thing, you know rides like a floor jack handles like a shifter cart. I'm a truck guy at heart and just ready for something different.
Old 03-26-2013, 03:19 PM   #7
jimmydean
jimmydean's Avatar
The Dropmember is a proven design, not saying there aren't options, but for me there aren't. To see guys like Dino run it for years and continue to run them says a lot.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 03-26-2013, 05:56 PM   #8
ulakovic22
The SP500 is only offered in a 5 lug and 19" is as big as they will go on that wheel as well. If you are doing 5 lug conversion (5x127) and can find a 19" tire that you want to run you should be GTG. You might want to look at either a 18 or 20 just for tire choice and $$. I had a G8 which came with factory 19's and tire selection sucked.
ulakovic22 is offline   Reply With Quote
Old 03-26-2013, 07:09 PM   #9
FOSTER21
I wish they would make the SP500's in a 20
Old 03-27-2013, 02:13 AM   #10
andrewmp6
If you want it lowered good the mid dropmember is prefect the extreme one is good if you want the truck to lay frame.The rack and pinion it uses is a easy off the shelf part a 79-93 mustang.They center the front wheels in the wheel openings which looks better and gives you more room to ride low with big wheels.
Old 03-27-2013, 02:30 PM   #11
FOSTER21
What is the maximum ride height on the extreme? We have some pretty sh!ty railroad crossings around hear.
Old 03-27-2013, 05:09 PM   #12
Pro Performance
You can lift up for the rough roads, but doing so will require more air pressure and make for a stiffer ride. I would maybe suggest the touring in this case, which still can lay frame depending on the height of tires.
I am not sure on the exact measurement of the ride height on a extreme, as the tire diameter (and drop spindle) also plays a role in this.... but it is low!
