Old 03-28-2013, 05:06 PM   #1
BrookelynnGreen
BrookelynnGreen's Avatar
Rear End Swap Questions
I have an 86 Silverado SWB & 86 C10 Custom Deluxe SWB. I'm fixing up the Silverado and using the C10 for parts. The C10 has a posi rear end and the Silverado has a limited slip. I'm wanting to swap the rear ends so the Silverado has the posi. So my question is:
Should the C10's posi bolt right up to my Silverado? and vice verse?
Thank You!!
-Samuel
"Knowledge Is Power"
BrookelynnGreen is offline   Reply With Quote
Old 03-28-2013, 07:49 PM   #2
LONGHAIR
Re: Rear End Swap Questions
If you a talking about factory original parts, they are both the same.
They are Eaton Gov-loc units, referred to by GM as the option code G80.
"Posi-traction" is just Chevrolet's term for a clutch-type limited slip differential, the are the same thing.
But, a Gov-loc is not as simple as that. They are a "self adjusting" unit that is supposed to be an up-grade to the original.......not so in the opinion of most.
Either way, unless it has been modified by a previous owner, neither truck has a traditional Posi-traction in it.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-28-2013, 07:58 PM   #3
BrookelynnGreen
So can you please tell me what I need to look for before I do the swap to at least ensure that it will go smoothly. Thank You.
-Samuel
Old 03-29-2013, 05:39 AM   #4
FLEET72
FLEET72's Avatar
I'd start by pulling the covers and comparing them. Like Longhair says, they are most likely the same.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-29-2013, 08:30 AM   #5
LONGHAIR
Unless you are swapping for a gear ratio change, which you haven't mentioned, there is no point.....everything is the same.
If this is for a gear ratio change, swap the entire housing, not the internals.
