#26 | |
![]() Join Date: Jun 2012
Re: Fat Blocks and Rear Ends
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
#27 |
Registered Truck Offender
That's their pro gear and spool setup. They claim good to 1500HP and 7seconds in a 2500 pound chassis. I've torn up lost of stuff in the low 9 second Nova,, but not a hint of trouble from the rear. Yes they are staggered, and exactly because of the issue you said,, no access to the bolts. Also I'm assuming they were looking for additional clamping to avoid gear deflection, without taking away from the mass with all large holes?/ I have no idea really, you'd have to ask the engineers. They design / build it,, I just try to destroy it. LOL
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#28 | |
#29 |
I'll bet that even though it cost us our hard earned money, everytime we break parts like rears in our trucks we grin and thump our chest deep down inside? I know i'm guilty of it.
'71 LWB c10-"WORK" in progress ![]() 385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall 2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better) 2013 best 7.39 2014 best-7.38 New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage |
#30 | |
#31 |
Im using a Rick Jones chromo housing with 3.5 axle tubes. It sounds crazy but people tested with shock sensors attached to the axle tubes on each side. They discovered the tubes where flexing going down the track. Jeg Coughlin was one of them , Greg Stanfield was another. When the new rear end was built with more bracing and bigger tubes, both cars picked up almost .5 a tenth. That is huge in Pro Stock , and the cars are only 2300lbs. I may add some turbos at some point so I wanted to start with something stout to begin with.
#32 |
I am still debating on what to use. i know that i will not use the factory 12 bolt, knowing that it will explode with my motor that I,m running. that said i,m still looking at different aftermarket axle builders to see how much i have to spend to make it all work. The number one thing is that i do not want an axle that will not hold up. being stranded on the side of the road is not an option...
#33 |
At the body shop.
Did a eBay 9" with ex NASCAR stuff on the cheap. 3.25" bearing 31 spline Detroit locker for 200$ and 3:82 edm polished ring and pinion for 79$
Havnt killed it yet 1.67 60' @ 4160lbs and street miles. Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
#34 |
Ya i have been looking at some of the Nascar stuff, Just not seen one I like yet. and some of the prices are cheap..
