11-12-2012, 12:23 AM | #76 |
Re: ls turbo build
How's the install coming?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-12-2012, 09:42 AM | #77 |
Re: ls turbo build
Jegs sent the wrong flexplate.... I have to use the crank spacer (555-601010) and a FLAT tci flexplate (399753). They told me that the hughes flexplate (512-hp4004x) will work... But it's dished and won't allow the converter to pull up enough to bolt up to the flexplate... So if you install the spacer first then the TCI flexplate it will work....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
11-12-2012, 10:28 AM | #78 | |
Re: ls turbo build
11-13-2012, 07:12 AM | #79 |
Re: ls turbo build
Great progress thus far brother. Got the motor in but ran into a snag with the turbo fitment. As usual I will be keeping a close eye on yours.
11-13-2012, 10:13 PM | #80 |
Re: ls turbo build
killer setup,, should be sweet,, keep us posted!!
11-14-2012, 10:48 PM | #81 |
Re: ls turbo build
Will do. My goal is 500 to the wheels. Really don't want to blow this 6.0 up...they are becoming harder to find...and pricier to boot.
11-15-2012, 04:16 PM | #82 |
Boosted Member
Re: ls turbo build
Looking good. Following your progress.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
11-17-2012, 02:56 PM | #83 |
Re: ls turbo build
69trk- Do you post on MWSC as well? That pic of your truck in the avatar looks familiar. I had no idea you had all this turbo/ls swap going on! Nice work so far.
'49 Chevy 5window/S-10 frame. LS 408ci/4l80 '71 Chevy C10- Sold a long time ago. |
11-17-2012, 03:23 PM | #84 |
Re: ls turbo build
Yep, i'm over there....
11-29-2012, 10:16 PM | #85 |
Re: ls turbo build
Got motor and trans installed today.... Went real easy and motor mounts worked perfect!!! So i don't have to cut or lengthen my 3.5" aluminum driveshaft.... Engine slides real easy with these mounts... Now i have to order the steam line kit that uses the fronts and rears and then order my pro flo xt intake and throttle body... But for now i can install my driveshaft, shifter, radiator and hydraboost unit..
11-29-2012, 10:17 PM | #86 |
Re: ls turbo build
Look at all the room in front of the engine... Turbo should be fairly easy
11-29-2012, 10:54 PM | #87 |
Truck and auto performance nut
Re: ls turbo build
looks like you could even move the motor back a bit
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-30-2012, 12:43 AM | #88 |
Re: ls turbo build
It looks great! I wouldn't move it at all. Leaves plenty of room to reach around and lots of clearance for that tall intake manifold. That thing is clean!
01-21-2013, 09:45 PM | #89 |
Re: ls turbo build
Haven't posted in a while, just trying to save for the new baby coming in early may. But i did order a ron francis wiring kit that came in today, that should keep me busy for a little while. I cut all the old wiring out of the truck, man what a mess lol....
01-21-2013, 10:05 PM | #90 |
Re: ls turbo build
Heres some picts of the wiring and the shifter. Not sure if im going to like the shifter or not. My helper wanted in the picture also..
Posted via Mobile Device Posted via Mobile Device
01-23-2013, 12:27 AM | #91 |
Re: ls turbo build
Hey stranger, I just found this thread. I didn't know you were hiding over here in the LS section. Man your are kicking this up a big notch! That engine looks awesome in there. I will have to come over and check it out sometime.
On another note, I saw in the okie summer meet thread about your wifes due date and mine is due the same time..
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
01-24-2013, 09:49 PM | #92 |
Re: ls turbo build
Must be one of the roofers lol
02-23-2013, 11:24 PM | #93 |
Re: ls turbo build
Just picked this up today for $375!!
02-24-2013, 03:06 AM | #94 |
Re: ls turbo build
Great build so far, keep it up...!
03-21-2013, 11:31 PM | #95 |
Re: ls turbo build
Hey 69 I'm from dfwss and mwsc I starting a turbo build soon. Starting to gather parts. Thanks for sharing the build now part numbers.
Can use pm me a link to those mounts? I have same stands as u and I am going with f body oil pan. Thats the same intake I wanna run can't wait to see some numbers |
03-22-2013, 06:25 PM | #96 |
Re: ls turbo build
The upper engine mounts are 355-3-1114g.
And the dirtydingo sliders just say dd-slider... I sent you a pm...
03-31-2013, 04:20 AM | #97 |
Re: ls turbo build
Where u gonna mount turbo?
03-31-2013, 04:24 PM | #98 |
Re: ls turbo build
Not sure yet. I'm moving the ac compressor up towards the top and i need to make sure the headers or a log style manifold will miss the ac compressor...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 Last edited by 69trk; 03-31-2013 at 04:31 PM. Reason: mis spell |
03-31-2013, 04:29 PM | #99 |
Re: ls turbo build
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
03-31-2013, 04:33 PM | #100 |
Re: ls turbo build
Ive been looking at that, but needs to be a t6 flange. And i think the turbo would be sitting to close or in the way of the ac compressor. Unless i move it to the driverside?
