Old 04-02-2013, 07:49 PM   #1
REEDS 72
REEDS 72's Avatar
Rag Joint
Has anyone seen a rag joint with this wire? Is it a ground wire? Came off of a 72 Chevy. This is the only one I have seen.
REEDS 72 is offline   Reply With Quote
Old 04-02-2013, 08:05 PM   #2
yuccales
yuccales's Avatar
Re: Rag Joint
Yep, ground.
yuccales is offline   Reply With Quote
Old 04-02-2013, 08:09 PM   #3
HotRod C/10
HotRod C/10's Avatar
Re: Rag Joint
Mine has it.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 04-02-2013, 09:15 PM   #4
vidman
vidman's Avatar
Re: Rag Joint
mine had it also
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 04-02-2013, 11:22 PM   #5
anglebinder
Re: Rag Joint
Have a 67 chevy all stock, going to drop spindle 2.5" and 4" drop springs in rear. Any prob. with drive shaft? any other issues to prep. for? Thanks for any help!
anglebinder is offline   Reply With Quote
Old 04-02-2013, 11:39 PM   #6
FirstOwner69
FirstOwner69's Avatar
Re: Rag Joint
My 69 has one too.
FirstOwner69 is offline   Reply With Quote
Old 04-03-2013, 12:10 AM   #7
HotRod C/10
Re: Rag Joint
Might try posting in the forumn instead of someones thread. Get more help that way
LS SWAPPED
-1976 SILVERADO
Old 04-03-2013, 12:16 AM   #8
anglebinder
Re: Rag Joint
You're right, just figured that out. I'm new online,
Thanks for the reply.
Old 04-03-2013, 09:35 AM   #9
Longhorn 70
Longhorn 70's Avatar
Re: Rag Joint
Mine has that wire too. I recently replaced the steering box and cleaned things up while I was doing it. I must have missed the wire the first time while putting things back together...... Everything worked as it should including the horn. I saw the wire connector hanging out a bit later and took it apart again and installed it properly. Everything still works and now it's prettier.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
