Old 04-01-2013, 05:25 PM   #1
twich3136
twich3136's Avatar
14 bolt in a 68 longhorn?
I found a 14 bolt from a 99 silverado for 300 bucks. I can't seem to located any useful information about dimensions. The truck is leaf with an ho52. I know the 14 bolt will be wider but by how much is what I'm wondering. I know The perches will have to be moved and it's heavier. Any ideas what issues I might find?
USMC
SEMPER FI
68 Chevy Longhorn 350/400 factory posi
twich3136 is offline   Reply With Quote
Old 04-01-2013, 06:38 PM   #2
argonaut
argonaut's Avatar
Re: 14 bolt in a 68 longhorn?
I'm guessing here, but the late model 14 bolt is probably around 3 inches wider. You'll have to find someone who has one who can measure the hub surface-hub surface width.
You'll most likely need to cut off and weld on new spring pads and new shock mounts.
I'm not sure how heavy the HO52 is but I do know that the GM corp 14 bolt is on heavy SOB! I can lift a fully dressed 12 bolt into the bed of my truck by myself, and I can barely lift of side of the 14 bolt!
I'm wondering why you want to remove the HO52? If it is mechanically sound I'd run it. Unless it is a semi-floater. I hate semi-floating axles, such a poor design.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 04-01-2013, 07:08 PM   #3
twich3136
twich3136's Avatar
Mostly I'm trying to go to 4 wheel discs. This 14 bolt has factory discs. Later down the road it'll get a 4wd conversion. That'll be the fun tricky part. I like my ho52 and ill probably rebuild it for a different truck later because it has the original posi but for this truck it's about modernizing. The ho52 is frustrating because there is so little aftermarket.
I think this 14 is a full float. I really don't know if my ho52 is ff or sf. 3 inches wouldn't be too bad. Brakes might be a bit tricky to hook up I imagine.
USMC
SEMPER FI
Old 04-01-2013, 07:13 PM   #4
twich3136
twich3136's Avatar
This is the axle. I'm still waiting to hear back from him. It doesn't come with the springs which save me the trouble of relocating the hangars. Although I have a sneaking suspicion my springs won't match the perches
USMC
SEMPER FI
Old 04-01-2013, 07:19 PM   #5
argonaut
argonaut's Avatar
The axle in the photo looks to be a semi-floater to me. Not sure if that matters to you or not. Springs or no, I'm betting the spring-to-spring width on the newer axle is different from the old on, but i could be wrong.
You can easily adapt disk brakes to the HO axle http://www.ruffstuffspecialties.com/...g/EHO5272.html
But the trick is getting a small bore master cylinder for the rear. These brackets fit GM "D52" type calipers. but you'll need a small bore, smaller than the fronts. 78-79 Eldorado calipers and wilwood calipers will work if i remember correctly.
The newer axle is probably a safer route if you don't mind the fab work and welding.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 04-01-2013, 07:29 PM   #6
twich3136
twich3136's Avatar
I have found some options for converting to disc on the 52 but I worry about replacement parts when it finally goes out. Also part of my reasoning to go newer. It took me an hour to get a diff cover seal from napa because he thought I was crazy. I guess he's not very familiar with old Chevys. After fabing some Chevy axles to a yota I'm not too concerned about the fab work on the Chevy.
I feel like I read somewhere that the newer springs are a tad wider than mine. If that's the case ill just convert the newer springs to work.
What are the pros and cos for ff vs sf?
I'm definitely saving that link
USMC
SEMPER FI
Old 04-01-2013, 07:47 PM   #7
argonaut
argonaut's Avatar
FF is just like a front axle. There is an axle hub, that rides on a hollow spindle. The spindle bears the load of the truck and the axles can slide right in and out. if you ever have an axle failure, or a differential failure, you're axles and wheels won't slide right out like on a SF.
Thats why I like full floating axles, but they are physically heavier.
Looks likey the 99 springs should be 2-1/2" wide. http://www.sdtrucksprings.com/index....oducts_id=7367
if I were you I'd try to get the springs with the axle. You may be able to make the later model springs work with some poly bushings for the wider hangers. Are your 68 springs 3" wide? Do they get skinnier or wider at the ends? The 99 springs are going to be longer, but you could relocate the spring hangers as well...
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 04-01-2013, 08:17 PM   #8
twich3136
twich3136's Avatar
My springs are somewhere around 58" so I'd have to relocate the hangers but I've been wanting newer springs anyway. Mine are rock hard. I can't say off the top of my head how wide my springs are but I know they aren't wider than 21/2" I should just get the springs too and do it all at once. Save me some trouble later.
USMC
SEMPER FI
Old 04-02-2013, 08:36 AM   #9
in deep 72
in deep 72's Avatar
I swapped in a 14 bolt into my '69 GMC (a long time ago so hopefully my memnory is still good). It was older than the one your using and it was a FF. I had to change the spacing between the springs by 2". Rather than cut the pearches off, I cut the fivits off the hangers and made 1" spacers to between them and the frame. It wasn't that bad of a job.
Going to a newer axle, especially if it already has disk brakes is a good upgrade. Although I'm more a fan of the FF. Here's a good link to 14 bolt info. Been a while since I've looked at it so not sure if there's much for SF info, but take a look. Might be helpful.
http://www.pirate4x4.com/tech/billavista/14b_bible/
in deep 72 is offline   Reply With Quote
Old 04-02-2013, 08:52 PM   #10
Mr. 250r
Mr. 250r's Avatar
Looks like a semi floater you can tell from the end of the axle and the pumpkin and yes they should be wider as mine was right at 3in wide/1.5in on each side although i had a full floater from an... 05 i believe
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 04-03-2013, 11:48 AM   #11
twich3136
twich3136's Avatar
The ff axles make sense and I kind of wish I could find a decent one but I don't plan on wheeling it. It's just needed for towing the quads to the dunes and a little sand or dirt roads. I think the sf will work fine for my applications and budget. Now if only I can locate an 8 lug front axle to get the 4wd coversion started
USMC
SEMPER FI
Old 04-03-2013, 02:55 PM   #12
twich3136
twich3136's Avatar
The axle came with a surprise.
USMC
SEMPER FI
Old 04-03-2013, 05:31 PM   #13
twich3136
twich3136's Avatar
Alright so next question. Master cylinder. I imagine with my 68 master cylinder it's going to push too much pressure to the discs and not enough to the front drums.. Probably causing the rear to lock up every time I hit the brake. Since I plan on putting discs up front could I use a 99 master with the 72 disc brakes or do I need to get a newer style caliper as well?
Or is there a company out there that thought of this already?
USMC
SEMPER FI
Old 04-03-2013, 06:00 PM   #14
twich3136
twich3136's Avatar
I found this. http://67-72chevytrucks.com/vboard/s...68&postcount=4 I might look into it for the front.
USMC
SEMPER FI
Old 04-03-2013, 08:04 PM   #15
kenbob87
kenbob87's Avatar
that looks like the factory gm gov lock.... be careful with that thing try not to hammer on that rearend too much they do NOT like abuse. i myself have destroyed three of them 2 in ten bolts and one in a 14 bolt... but then again i am a very "spirited" driver lol
kenbob87 is offline   Reply With Quote
Old 04-03-2013, 09:14 PM   #16
Redcap
Oh look! A Gov-Bomb!
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 04-04-2013, 03:04 PM   #17
twich3136
twich3136's Avatar
The gov bomb already went off lol. I could convert it to an open diff or get a truetrac. Anyone have one of those?
USMC
SEMPER FI
Old 04-04-2013, 10:41 PM   #18
LONGHAIR
Trutracs are great. I ran one in the front of a 4x4 with a very healthy bigblock and 40" tires. I did break an axle one time, but the differential was fine, and that is way over what they are recommended to take.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-05-2013, 02:59 AM   #19
argonaut
argonaut's Avatar
twich,
are you sure that is a 14 bolt? Now that I look more closely the housing and carrier really don't look like my 14 bolt...
I'm doing some reading and maybe yours is the smaller 9.5" SF 14 bolt?
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 04-05-2013, 03:27 PM   #20
twich3136
twich3136's Avatar
Yea your right it is a sf 14 bolt. I'm nowhere near it. Lol my brother has been doing all the work for me. I would like the 10.5 but the 9.5 will do just fine. It's been fun trying to coordinate from the other side of the planet ha ha
USMC
SEMPER FI
