Old 04-03-2013, 12:16 AM   #1
Runner76
Advice on 250 6 cylinder build
As part of my 77 C-10 project, I will be rebuilding the original 250 engine. In addition to the normal overall, I want to up the performance factor. I am thinking head work to increase compression to 9 to 1, three angle valve job, aftermarket cam, carb upgrade and headers. Has anyone done something similar? I realize dropping in a small block would be easier, but I want to do something a little different. Any thoughts or advise/suggestions? Would the results justify the effort and expense?
Runner76 is offline   Reply With Quote
Old 04-03-2013, 12:29 AM   #2
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Advice on 250 6 cylinder build
This may be your new favourite website
http://www.cliffordperformance.net
They'll have everything you want and need!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-03-2013, 01:33 AM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Cam will wake it up for sure
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-03-2013, 01:58 AM   #4
vegadesign
vegadesign's Avatar
It really doesn't take much to get a lot of power out of these
I have a 250 In my 70
Biggest cam with some roller lifters,
Made a adapter for the two barrel carb and I'm kickin aprox 250-300hp
They are great engines and are often underestimated with power and design
I you can run more than one carb or a four barrel for better fuel/air mixture you will be set
Oh and I almost forgot!!
I get 25 mpg
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 04-03-2013, 06:25 AM   #5
D13
D13's Avatar
1. You will spend a lot more money for less HP on the six. BUt it's cool.
2. Search for 250 build in this and the Engines sections.
3. Google and join Inliners.
4. Buy Leo Santucci's book, 2nd edition. A must have.
307 pistons or Ross forged pistons from Tom Lowe, cast headers from Langdon, Clifford or Offy intake, cam that matches your RPM range. Next step - turbo.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
