Old 04-03-2013, 03:24 AM   #1
ozkiwi
oil filter access with headers ????
I have these headers from summit racing and was wondering if the oil filter access is still going to be ok.It looks pretty tight in there.Has anyone had a problem with this when installing long tube headers????
http://cgi.ebay.com.au/ws/eBayISAPI....m=390568924655
ozkiwi is offline   Reply With Quote
Old 04-03-2013, 08:37 AM   #2
77chevyinline6
77chevyinline6's Avatar
Re: oil filter access with headers ????
i have long tubes on mine and its tight but i can still access my oil filter.
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor)
350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator.
77chevyinline6 is offline   Reply With Quote
Old 04-03-2013, 08:45 AM   #3
88Jimmy4x4
88Jimmy4x4's Avatar
Ceramic coated headers require a special break in routine. This routine doesn't match the proper break in of a new engine. Might wanna add these later after engine/cam break in.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-03-2013, 12:35 PM   #4
meatwagon83
meatwagon83's Avatar
i can get to mine just fine, i have hedmanns
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 04-03-2013, 11:21 PM   #5
bilfman
bilfman's Avatar
I have ran headers in many different vehicles/styles/and configs , never have had filter access issues.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-04-2013, 03:12 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I put my ceramic headers on a long time ago and have had no issue with the break in, since the engine and the headers went in together.
Frank
Old 04-04-2013, 07:49 AM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
If you "properly" broke in your engine, then those temps will cause damage to the header coating, that will break down over time versus properly breaking in the headers thru heat cycles. It clearly states in the header instructions not to use during engine break in and it voids the header warranty.
http://static.summitracing.com/globa...54hkr_scan.pdf
Its just advice.....take it or leave it
1991 GMC Jimmy 4x4
Old 04-04-2013, 07:56 AM   #8
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
So what exactly did you do to break in engine?
If you "properly" broke in your engine, then those temps will cause damage to the header coating, dullness etc that will break down over time. It says in the header instructions not to use during engine break in and it voids the header warranty.
I read the Headman warning against using them on a non-broken in engine. I ended up still throwing them on the new engine for break in and broke it in at 2500 for 25 minutes. So far everything is fine. It was a cool day in Texas though (50ish degrees) so I don't know if that makes a difference.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 04-04-2013, 02:55 PM   #9
piecesparts
I did what I have always done, I did the original startup and set the RPMs for approximately 30 minutes to initially set the cam, however with a roller cam, there is less of a concern as it would be with a flat tappet one. I then drove the truck with a ight foot for the next 500 miles and from then on, it was short periods of heavy acceleration followed by a light foot cool down period. The headers were put on the truck in 1996 and they still have their finish, today. Maybe they will break down someday.
Frank
