#476 |
Re: DLoE's Dropmembered 65 StepSiDe Build
that front/rear bumper looks pretty cool!!!
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#477 |
![]() Join Date: Oct 2011
Bumper looks awesome bro!
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
#478 | |
chevy only
![]() Join Date: Sep 2006
CHEVY ONLY... Nothin Else ! |
#479 |
sweet! I booked my room today too!
Posted via Mobile Device |
#480 |
![]() Join Date: Mar 2013
I think somthings wrong. You should be making alot more power than that!
Expert racers that ride these say that yer setup should make over 200 hp and over or around 280 torque. Somthings wrong. According to factory 292 stock makes 265 torque and 150 hp. Somthing not right! ![]() ![]() ![]() |
#481 | |
However, what people are missing is that the Clifford cams are only designed for a standard head and their intakes, not for the additional flow that the lumps provide. Furthermore Walt went on to say that when you add lumps you not only need more cam, but then you must also have more carb. Apparently the Holley 390 is fine for just a standard say Clifford or Offy intake. Walt also told me that with lumps a 650 minimum on the carb but ideally you should be running a dual carb setup. This is because both the Clifford and Offy intakes have an inherent flaw. That is because of their design they do not flow the fuel supply evenly to all the cylinders. It seems as if the middle cylinders run lean on these sixes. Just some food for thought. |
#482 |
I'll post the specs of my cam later when I get home. dont have lump ports either. if feels like it has power, hmmm....
#483 |
welded on some license plate mounts to my rear bumper and slapped a coat of paint on her.
Posted via Mobile Device Posted via Mobile Device |
#484 | |
![]() Quote:
a lump port head? You would think that cliffords cam would work well do to the high lift! Do you have any cam reccomendations when using the lump port head? ![]() ![]() ![]() |
#485 |
no im not running lump ports.
#486 | |
My frame Layin 63 short bed project ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
#487 |
Damn dude this truck looks awesome!! Ive been thinking about painting mine brown at some point and this is making me think that it'd work....
Good build dude. ![]() |
#488 | |
alot more torque and hores power than that! Some say that the clifford cam is not very good quality. I went and looked at a clifford cam in person and they seemed to be good quality, but I know that a 292 should have alot more power than that. Especially since the clifford cam is high lift. And a holley 390 is a good carb for that. If you think about getting a new carb I would get an edelbrock 600 cfm double pump carb 4 barrel, thay are better quality by far than the holley. If your cam is flat you could get a delta cam they are great for racing and good quality. |
#489 |
Del Mar Right on! Loking forward to checking out your truck in person and meeting you-Rob
#490 |
thanks Rodrick (MadRods) for the Stepside sticker!
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
#491 |
Chevy Only Tx
No problem! If Dloes valves get famous hook me up with a sticker too
![]() ![]() Posted via Mobile Device
Chevy Only Tx......... |
#492 |
haha you got it!
#493 |
Sweeeet! ya gotta get a hook me up with a couple stickers too!!ha ha.
#494 |
such a nice step.....cant wait to see it this weekend
#495 |
chevy only
#496 |
alignment shop this morning, man I cant believe how much smoother it rides now, should have done that earlier lol.
#497 |
Hey DLoE!!!!!!!!!!!!!! I was hoping you could help me out. I am looking for a 292 water pump like yours. Are you using the original pump (just cleaned up),that came with your motor, or did you buy a new one for your build. Where can I find one? Thanks man! Looking killer!!!!!!!!!
#498 |
Hey paintman, its a new one I got from the truck shop in orange. you can get them at regular autoparts stores too. they are still avail.
#499 |
Nice build!
This is the first DMed step side build I have read. It came out great! Couple questions: Did they give you any other dyno sheets? I was curious how much torque it made at lower rpms? I always thought straight 6's were known for that. I've owned and built a few Jeep straight 6's and they were pretty much done by 3200rpms, which is about where your dyno pull started. I am also assuming that is rear wheel horsepower? I worked at a high end engine shop with 3 engine dynos and a chassis dyno. Street cars rarely made the power numbers that they were expected to, particularly on the chassis dyno. You said it feels like it makes good power. Other than maybe some carb experimenting I would just be happy with it. You don't seem too worried about it actually ![]() If you needed to how much lower could the bed floor be? I told the old lady I brought one more car home because I really needed a truck for trips to Home Depot and the plant nursery ![]() ...I also have dirt bikes so a little more depth might be a good idea for me. Thanks Posted via Mobile Device Posted via Mobile Device |
#500 |
good guys pics..
