04-04-2013, 12:53 PM | #1 |
Help diagnosing electrical problem?
Truck has been back on the road for a few weeks. Basically everything is new - motor, trans, complete wiring harness, starter, alternator, battery, etc. Swapped in a used automatic column with tilt, to replace the old column I had when I had the manual trans...
Go to start it yesterday, and nothing. Not even a blip from the starter. Try it again, and it fires right up. I am in a hurry for work, so I don't let it warm up as long as I should. Make it to the end of the street, and it dies. Go to restart, and nothing again. Dead as a doornail. Headlights work, but nothing that is "switched" power works. Won't start in Park or Neutral. Nothing at all. Get my wife to steer as I push it back into the driveway, and as I hit the end of the driveway it magically springs back to life. Power returns to AC. She hits the key and it fires right up! I have checked all wires and cables, and everything is tight. I am thinking that the ignition switch in my used, eBay-special tilt column is going bad. Sound like a reasonable thought?
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
04-04-2013, 01:42 PM | #2 |
Re: Help diagnosing electrical problem?
Years ago in my cutlass I had a similar situation but with no restart. It end up being a bad starter solenoid or a burnt wire at the solenoid. I can't remember which.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
04-04-2013, 03:18 PM | #3 |
Slots go on anything!
could be a bad or misadjusted ignition switch. If you replace it, use a Delco part.
04-04-2013, 04:49 PM | #4 |
78K & 79C Jimmys
i had a 86 Grand Prix that wouldn't start sometimes, finally fixed it but had to turn the colum back from around the dash area
NSS switch was outa wack
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-04-2013, 04:52 PM | #5 |
GM Addicted
What year is the truck??
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
04-04-2013, 05:06 PM | #6 |
1980 - the one in my signature. I need to take "after" pictures, now that I have completed a ton of work on it...
04-05-2013, 07:25 AM | #7 |
You might want to check the switch on your clutch
Scott 82 step side aka " Bouncy " 73 GMC Long bed Vortec 5.7 |
