04-01-2013, 04:00 PM | #151 | |
Re: My 56 6bt 4X4 build.
Stock dodge cable. Its a bit long tho. makes the pedal a bit stiff. May try to shorten . or maby just try a nice new cable .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
04-01-2013, 04:06 PM | #152 |
6>8 Plugless........
If it works for you, on that 89 Burb I did, I was able to retain the stock throttle cable. I just had to drill the hole a little bigger to slide over the dodge pivot ball. I then used a clip and end from another ford throttle cable I had to pop on the ball to retain the cable in place. Works great.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-01-2013, 11:31 PM | #153 |
The cool part of you truck build is when it drives by when your done, people will never expect the sound of a diesel should screw with a few heads, be like ..what..is that a diesel, no way...cool. Keep the work going, cool build for sure, lot to fab and modify that is why I appreciate it so much, a real build.
04-01-2013, 11:45 PM | #154 | |
04-01-2013, 11:58 PM | #155 |
That's true, most people in general don't really understand, some do but I get the 235 6cyl thing, haha.
04-02-2013, 12:27 PM | #156 |
Everyone will be telling you that you have a rod knocking!
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540 1992 Chevy K1500 Silverado ECSB 1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered |
04-03-2013, 06:19 PM | #157 |
Well driveshafts got sent today. Going to finish up steering tonite. Haven trouble getting the mush out of the brake pedal. Master might of been empty for too log during the axle swap. Goint to adjust up the rears and see if I get some pedal. This thing may even move a few feet under it's own power this wknd. !!
Luther I will try to get thise pedal pics tonite. I forgot . My Bad.
04-03-2013, 06:54 PM | #158 |
What did you come up with for the trans mount?
04-03-2013, 07:12 PM | #159 |
Chevy Enthusiast
6BT you need the 29 spline coupler specific to the getrag/205 http://www.ebay.com/itm/Dodge-Cummin...30858207866%26 http://www.enterpriseengine.com/shop...apter-coupler/ http://www.quad4x4.com/cgi-bin/comme...cton&key=10528 http://www.ebay.com/itm/np-205-np205...59218e&vxp=mtr
I would check the web for some feedback before ordering one. I hope this helps!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
04-03-2013, 08:43 PM | #160 |
Hi Ryan. In the name of simplicity I think im going to re use the dodge crossmember and use the orriginal style mounts.. Cheap And i was able to get them quickly, due to the configuration of the frame being so straight Im going to have to fab up some drop brackets but thats no biggie. I may make a mount for some trac bars off the drop bracket while im at it .
04-03-2013, 08:51 PM | #161 | |
Is the Gertag the same spline as the NV 4500? I wouldent have thought so ? Most of those links seem to give you that inpression tho. Hummmm.... now what . i guess I gave to hit the web to see whats up . Thanks again for the links .
04-03-2013, 09:26 PM | #162 |
Chevy Enthusiast
Yes all the 4x4 dodge manuals are 29 spline and will all bolt up to your 205 (not sure about the G56) but I was thinking that coupler only came with the 360/205.
04-03-2013, 09:36 PM | #163 | |
That makes more sence. I was going crosseyed just thiking abt it . I will oredr up one of those for sure. Whatever one is closer to canada i guess. Thanks again for the links .
04-03-2013, 10:21 PM | #164 |
Be careful, some NV4500's behind 318's and 360's are 23 spline.
04-03-2013, 11:07 PM | #165 |
Chevy Enthusiast
Yeah your right, I should have said diesels. Do you know what the V10s had?
04-04-2013, 01:07 AM | #166 |
pretty sure all the diesel and v10 trans are the same. they were the "HD" units.
04-04-2013, 12:57 PM | #167 |
Chevy Enthusiast
That's what I thought, they both have the bigger input shafts on the nv4500s also.
04-04-2013, 02:52 PM | #168 |
Yes, they have 1 1/4" inputs. But the bigger inputs are 1 3/8" when you go big. That is the same size as the NV5600 and G56 too.
04-09-2013, 11:35 PM | #169 |
So lots of progress in the last few weeks . It's up and running now. a few things still to do. the rad is shot. Just used it to make sure everything was going to work. I let it run in the shop for a few hrs tonite . got up to 195. still needs a fan as well. The t case shifter has to be moved up abt 6 inches too. looking forward to a test run if it ever stos raining.
04-09-2013, 11:36 PM | #170 |
Any one know what k&n filter fits on the front of the stock turbo. I see lots of trucks with a nice stubby one that fits quite well.
04-10-2013, 12:22 AM | #171 |
Chevy Enthusiast
Don't go with K&N, just about any filter other than that should be fine just not K&N.
04-10-2013, 12:37 AM | #172 |
I hear that it takes a big filter to provide air for these things. I have seen stubby filters sucked in on themselves.
04-10-2013, 01:07 AM | #173 |
Chevy Enthusiast
If you get a couple 90s or a big U you could run a BHAF, or you could just get a stock 2nd Gen intake pipe and do the same thing. I don't think the 1st Gen pipe is long enough.
04-10-2013, 10:27 PM | #174 |
Well tonite was the fitst drive. It's noisey , rattles , no cup holders and it rides and handles like a hay wagon. Yep love it. It needs a few tie rod ends and the drag link is ng. I knew abt this tho. Was wating on the draglink till i got it figured out what I wanted to do. Going to do a link using gm ends like Ryan did on the V rig. This should take care of the haywagon handiling . Still need a air filter. Make a new mount for the T/c shifter, move it up abt 6inches.
Im also thinking Im going to have to make up some kind of track bars. This truck has only got 1/2 ton springs in the rear. That combined with a 4inch block for the rear lift and a lot more torque on tap and it tends to waunder around a bit in the rear when you stomp on it or decellerate quickly. Some bars should help eliminate the axle wrap and keep me going in a straight line. Any one built any before ? Any pics ? Ryan I'm sure you can contribute
04-10-2013, 11:03 PM | #175 |
THAT IS SO COOL!!! Love it. No advice though, I don't even have mine on the road yet but am truly inspired
I pity the fool with only 2 headlights! |
Tags |
4x4, cummins, napco |
