04-05-2013, 09:48 PM | #1 |
granny gear 4spd cross member question
can I install my th350 in my truck with the granny gear 4spd cross member still in the truck
04-06-2013, 01:32 AM | #2 |
60-66 Nut
Re: granny gear 4spd cross member question
If you are talking about the bellhousing crossmember, I always recommend removing them when converting to an auto trans. Then you will need a trans crossmember for the rear of the TH350. Any stock truck based auto trans crossmember from '63-'87 will work. You will just have to drill the holes to bolt it into the frame.
Tags |
4spd, c10 2wd fleetside, chevy, th350, truck bed |
