Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-05-2013, 11:57 PM   #1
low&slow
Traction Problems/Time slip
Got a 69 c10 long bed with everything stock except the engine. Truck has been gutted. The rear end is limited slip posi track. I took it to the test n tune this past weekend and could not get the truck to hook very well. My first few passes were on street tires leaving the light at 2200 rpms, spun the tires. One of my buds at the track let me borrow his slicks that are roughly 10 inches wide. Warmed them up and launched at 2200 again, but still spun the tires. Tried again launching at 1800 RPM's, did a lot better, but still spun before it decided to grab.
I'm sure I need to upgrade the drive train, but cash is REALLY low. What can I do to get the truck to hook better?
Also, my time slip info: (not sure if its good or bad)
R/T: .078
60': 1.972
1/8: 8.443
MPH: 83.02
1/4: 13.053
MPH: 100.56
The engine is a 500 Cadillac. Aluminum intake. 750 double pump holley. Headers. Stock heads that have been ported a little. Everything else is stock.
Dyno says the engine is 563 fpt and 477 hp. Not sure what its getting to the rear wheels though. The transmission is a 700R4 with a shift kit. For those that may question me, I have a BOP/Chevy Transmission Adapter Plate.
low&slow is offline   Reply With Quote
Old 04-06-2013, 12:41 AM   #2
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Traction Problems/Time slip
What size tires are you running and what are your gears? That low first gear is gonna be tough to control! I'd recommend a 30" tall tire to help bring the ratio down.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-06-2013, 01:06 AM   #3
low&slow
I have no clue what the gears are. I got the transmission off of craigslist and the rear end is a stock posi. As for the slicks I ran, I have no idea what size they were. They were on a 15x10 rim. They seemed pretty tall, but I could just be seeing things. The tires I ran myself, I don't know off the top of my head. I will take a look. They are pretty small.
Old 04-06-2013, 01:26 AM   #4
69GMC910
MOTORHEAD!
69GMC910's Avatar
Any video of your runs? Pretty decent time/mph!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 04-06-2013, 01:56 AM   #5
low&slow
I don't have any vids yet. As soon as I start a build thread, I will get some vids. I only went to the track because my bud paid for me and towed me out there lol. I wasn't really prepared to say the least,
The tires I was running before the slicks are 295/60R15
Old 04-06-2013, 04:18 AM   #6
low&slow
Since you mentioned that I should go with a 30'' tire, would a 31/13/15 tire fit a 15x10 rim?
Old 04-06-2013, 08:37 AM   #7
RexDodge
Be sure to check your footprint/air pressure. Roll through a wet spot and measure the width of the track left by the tires when you roll out of it. Air em down until you get the width of the tire you are running. You'll be surprised at the difference.
RexDodge is offline   Reply With Quote
Old 04-06-2013, 03:36 PM   #8
low&slow
I'll defiantly give that a try.
Could I also be launching at too high of an RPM? The engine idles at about 800 and all peak hp and torque are between 2300-2700 RPM's.
Old 04-06-2013, 04:48 PM   #9
Marv D
Registered Truck Offender
Marv D's Avatar
Also keep you front street tires out of the water,, they drag water to the starting line,., obviously don't help you cause a bit. Big issue is weight,, you have 80% of it on the nose and nothng on the tailgate. Those big Caddy motors ae a real porker, and make buttloads of torque in a lower rpm range. hell launch from idle and your making more torque that many stout sbc's
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-07-2013, 09:20 AM   #10
vin63
It's Better With Nitro
vin63's Avatar
A couple of things. The 700R4 has a 3.06 first gear, which is a lot for the torque the Caddy makes. Second, that transmission is not going to last much longer (I would strongly recommend a TH400 or a 4L80E). There are a lot of unanswered questions (rear gear ratio, tire diameter, air pressure, etc.) that were asked earlier that we'll need answered before providing any relevant recommendations
I would bet the Caddy is making over 400 ft-lbs off idle, so I would just leave off idle in the meantime. Assuming you were at Firebird, what was the dew point and how was it prepped?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-09-2013, 01:33 AM   #11
BigDan3131
BigDan3131's Avatar
I thought first gear in a 700R4 was 3.06?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 04-09-2013, 03:56 AM   #12
low&slow
Originally Posted by vin63 View Post
A couple of things. The 700R4 has a 2.52 first gear, which is a lot for the torque the Caddy makes. Second, that transmission is not going to last much longer (I would strongly recommend a TH400 or a 4L80E). There are a lot of unanswered questions (rear gear ratio, tire diameter, air pressure, etc.) that were asked earlier that we'll need answered before providing any relevant recommendations
The street tires I was running were 295/60R15 on 15x8 rims. The slicks I ran were 27.5X11.5R15 on 15x10 rims. I have no clue what the pressure was on either sets of tires.
If I do end up getting a TH400, would it be best to have a shift kit in it or not?
Also, it was a pretty decent out that weekend and I don't know how they prep it.
If I was to launch at idle, what would be the best way to launch? Pedal to the metal or ease into it?
Also, I'm not so sure about the whole weight thing. These motors weigh less than a 454. With this caddy in my truck, my front end actually sits a tad higher than the rear. But then again, the rear springs could be worn out. I'll try to find some friends that have scales and see if I can get the weight of the front and the rear and compare them.
Old 04-09-2013, 01:13 PM   #13
chevy72blu
chevy72blu's Avatar
Keep in mind that if you are able to make this truck hook, it wont be long for life on that stock drive train. The weakest link will pop... Unless you plan on replacing the trans, drive shaft, u joints, rear end, etc in short order, it may be a better idea to simply let it slip a bit. Feathering the throttle out of the holeshot always worked well for me on street tires.
Impressive times, though! I'd love to see pics.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-09-2013, 08:02 PM   #14
vin63
vin63's Avatar
You're correct...my typo edited.
Old 04-12-2013, 11:27 PM   #15
gofastnut
gofastnut's Avatar
Sounds like fun! I'd love to see pics. A vid would be even better!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 04-15-2013, 01:14 AM   #16
low&slow
I am very aware of that. I just want to see how fast I can go with everything being stock. Once one thing brakes, then EVERYTHING will get replaced and built up before it touches the track again.
