04-08-2013, 08:41 PM | #7351 |
Re: What did you do to your truck today?
setting up checking out how things will look
project 66 flat n low |
04-09-2013, 12:10 AM | #7352 |
put on new rear breaks
04-09-2013, 01:42 AM | #7353 |
changed the oil with brad penn
and balanced the front tires.
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
04-09-2013, 08:01 AM | #7354 |
Cool look SoCalJess.
04-09-2013, 08:05 AM | #7355 |
Thanks Chris!
04-09-2013, 09:04 AM | #7356 | |
sam Last edited by luvbowties; 04-09-2013 at 09:20 AM. Reason: grammar |
04-09-2013, 01:22 PM | #7357 |
Thanks Robber
04-09-2013, 04:39 PM | #7358 |
well painted front drums, and put in new sparkplugs, also bled brake lines!
04-09-2013, 08:56 PM | #7359 |
Cleaned, primered, and painted the front sway bar and mounting brackets.
Worked on repairs to my hacked up low floor tunnel cover while the parts were drying... I hope to finish it up tomorrow. rg |
04-10-2013, 06:14 PM | #7360 |
Installed clutch master cyl and linkage, bent a line and bled. Works like a million bucks. Started on power booster, thanks to Captain Fab for the quality parts to work with.
04-10-2013, 08:29 PM | #7361 |
Wheel and tire sizes please!!!!!!!
65' Chevy C-10 Shortbox |
04-10-2013, 08:48 PM | #7362 |
Installed factory front sway bar (78 burb) on drop frame brackets.
With the frame being boxed and a REZ kit, I had to drill and elongate some access holes for the wrench on each of the back two frame bracket mounting bolts, but it worked out okay. I think I'll get fresh bushings since these had quite a few cracks show up after everything was all tightened up. rg |
04-10-2013, 09:02 PM | #7363 |
Spent the afternoon at the alignment shop....
04-10-2013, 09:15 PM | #7364 |
@78f1hundo im running 20 inch velocity 5 spoke wraped with 255/45/20 yokohamas parada spec x tires
04-10-2013, 09:21 PM | #7365 |
Painted the front half of the 65 frame with POR-15.
04-10-2013, 09:34 PM | #7366 |
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
04-10-2013, 10:56 PM | #7367 |
[IMG][/IMG]Cleaned out old bed wood and took the inner wheel tubs out
04-10-2013, 10:58 PM | #7368 |
[IMG][/IMG]Start sanding bed
04-10-2013, 10:59 PM | #7369 |
Why are my pics so huge ????????
04-11-2013, 12:53 PM | #7370 |
Painted the bellhousing and moved the rear end up on a big wooden box to finish cleaning and painting it.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
04-11-2013, 03:27 PM | #7371 |
Here you go..
Posted via Mobile Device |
04-11-2013, 04:18 PM | #7372 |
GMC's n H.D.'s too!
Hey... that's not showing much frame! Nice 292 though!!
04-11-2013, 04:52 PM | #7373 |
04-11-2013, 07:53 PM | #7374 |
Just finished sandblasting a arms and motor mounts [IMG][/IMG]
04-11-2013, 08:55 PM | #7375 |
I disassembled and painted my deluxe heater switch setup. I just dremeled the rivet heads off an painted it then drilled and tapped for a 4-40 machine screw right where the rivets were. Be careful not to drill through now! Really easy. I can't seem to add a photo from my phone as i don't know how. I will add it later from my computer.
Posted via Mobile Device Posted via Mobile Device |
