Old 04-08-2013, 10:37 PM   #1
Fury5Paws
Istrument Panel Gauge swap ?
Does anyone know how to do an instrument panel swap? From a 67-72 newer panel to a 67 chevy that only has the spedo and fuel gauges. Plus the idiot lights for the oil and temp. (have a full guage cluster for my truck-67 Chevy C10-Need help installing newer guage cluster panel. Thanks
Fury5Paws is offline   Reply With Quote
Old 04-09-2013, 07:55 PM   #2
sduckworth13
sduckworth13's Avatar
Re: Istrument Panel Gauge swap ?
Look up GMC Pauls website they have the cluster swap info on their website.
http://gmcpauls.com/Tech%20Tips1.htm
Swapping A Idiot Light Dash Out To Gauge Dash
The following is for a gauge dash this gives the numbered position of the wires in gauge dash and followed by what it supplies, then number from idiot light dash you move wire from.
1-Black with white stripe 18g(alternator) This runs from the 12g R wire from voltage regulator and should have 1-4amp inline fuse.
2-Tan (Brake warning light) Original position 2
3-Pink (Fuel Gauge) Original Position 7
4-Tan(Fuel Gauge) Original Position 4
5-Empty(not Used)
6-Dark Green (Temp. Gauge) Original position 5
7-Black(ground)Original Position 6
8-Gray(cluster light feed) Original Position 12
9-Medium Blue (Right turn) Original Position 11
10-Lt. Blue (left turn) Original Position 10
11-Lt. Green (high Beam indicator) Original Position 9
12-Black/w brown stripe 18g use wire ran from the junction block near battery mounted to passenger side fender with 1-4amp inline fuse located at junction block end.
Remove the wires from your loom plug and place the colors in the # on plug that corresponds with the color from list above. You will need to replace your idiot light temp. gauge for a temp. sending unit with gauges. The black and white wire feeds from the 12gRed wire off back of alternator and requires the use of 1-4amp inline fuses, this wire you need to make and run. The DARK BLUE wire that was originally in #1 position should be deleted because this was the idiot light for the oil pressure. If you need more info. ask.
Scott
sduckworth13 is offline   Reply With Quote
Old 04-09-2013, 07:57 PM   #3
sduckworth13
Might ask a moderator to moved this to thread to the electrical section for you.
Scott
