Old 04-09-2013, 01:57 AM   #1
Fw190d9
Project "Estelle"
Howdy all, I have just finished swapping a 5.3 into my daughter's 71 C10 Cheyenne "Estelle". (she dubbed it so when we bought it) I found the process so easy and enjoyable that I thought I would post some pics of the transformation. I was a bit intimidated of all the unknowns of swapping a modern engine into an older vehicle but with all the threads on here showing all the successful swaps I figured I would just dive right in.
First up, the day we brought Estelle home and my "favorite" daughter driving her baby.
Fw190d9 is offline   Reply With Quote
Old 04-09-2013, 01:59 AM   #2
Fw190d9
Re: Project "Estelle"
Next we have the old tired 350, prepping to come on out of there
Evan Q.
Old 04-09-2013, 02:02 AM   #3
Fw190d9
Next step was to call my buddy who runs a wrecking yard and put in an order for a 2006 5.3/4L60e out of a Tahoe with only 37k miles on the clock. Got the full harness and tac module with gas pedal also.
Evan Q.
Old 04-09-2013, 02:05 AM   #4
Fw190d9
Next order of business was to finish yanking that tired old mouse motor. I scored an engine leveler to use with my shop crane and was able to yank it with the tranny no problemo.
Evan Q.
Old 04-09-2013, 02:08 AM   #5
Fw190d9
Oops, forgot this pic
Old 04-09-2013, 02:11 AM   #6
Fw190d9
I then proceeded to stare at the wondrous 5.3 in all its glory for a bit. Then remove the harness, manifolds and motor mounts.
E.
Old 04-09-2013, 02:14 AM   #7
Fw190d9
Once I bolted up the Dirty Dingo slider mounts, I decided to go ahead and test fit. It fit so well I never took it out again. I moved the crossmember back 2.5 inches and drilled it for a single mount bold in the center. I also installed the Dirty Dingo A/C compressor mount as Estelle already had Vintage air and needed the sanden compressor.
E.
Old 04-09-2013, 02:17 AM   #8
Fw190d9
pics
Old 04-09-2013, 02:26 AM   #9
Fw190d9
Got a stand alone harness from Speartech(great service and product BTW) to speed things up a bit. Some cool ceramic coated headers from Doug Thorley which were a breeze to install and fit perfect with no mods. I had a dual electric fan kit from Entropy left over from a previous blazer project that fit perfect. Scored a spectre intake kit on ebay for cheap bucks and got some radiator hoses for a 90s something chevy truck. I even found the number of serpentine belt to use with the DD ac mount right here on the forum(It pays to Lurk!)
Old 04-09-2013, 02:31 AM   #10
Fw190d9
MSD adjustable plug wires clear all the header tubes nicely. Used the original power steering hoses and only needed to weld up one fitting. I plumbed the trans cooler lines with braided hoses and an fittings.
Old 04-09-2013, 02:34 AM   #11
Fw190d9
I then took my ECM to my corvette tuner and had him flash a program on it to remove the evap stuff and found a plastic ECM mount on GM parts website. I made a custom mount from 1/8 steel strap to mount the ECM and TAC module to the inner fender.
Old 04-09-2013, 02:38 AM   #12
Fw190d9
Mounted some new O2 sensors to the doug thorley headers and built a mount for the gas pedal out of some 16 ga steel.
Old 04-09-2013, 02:42 AM   #13
Fw190d9
Ordered up some 2.5" exhaust pipe sections and some flowmaster look alikes from summit and proceeded to weld up a crimpless dual exhaust system
E.
Old 04-09-2013, 02:48 AM   #14
Fw190d9
I used a walbro pump and a C5 corvette filter/regulator on the passenger frame rail and mounted a blazer tank to the rear frame rails(didnt like the ideal of my little girl sharing a cab with a gas tank). The tranny fits beautifully and I had to shorten the front driveshaft exactly 2.5". The original TH350 yoke fit the 4L60E perfectly. The stock tahoe oil pan hangs about 1" below the front crossmember which still gives me plenty of ground clearance.
Old 04-09-2013, 02:53 AM   #15
Fw190d9
Now heres the really cool part. After all this installation stuff, I turned the key on and off a few times to make sure the fuel pump was pumping, then turned the key to start and she fired right up on the first crank! Runs fantastic. Never had an engine install go that easy before. Performance is outstanding, Poor ol Estelle never had so much smooth power before. Bad part was I made the mistake of letting my 15 yr old son drive it, now he wants one too...
Evan Q.
PS, thanks to all you guys on this forum for providing so much great swap info, really made my job easier.
Old 04-09-2013, 05:59 AM   #16
chuckmc8
It's alsways something.....
chuckmc8's Avatar
I love that truck- I learned to drive in a brand new twin of that one in 1971.
I just finished a 5.3 swap into my 71 2wd Blazer. It is amazing how good they run in these trucks, and how EZ the install is. I am running 4L60 with 3:73 rear, lots of fun if someone had a tendency to squeal the tires ;-)
There is no going back once you drive a 67-72 with LSx power
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 04-09-2013, 08:20 AM   #17
68Stepbed
68Stepbed's Avatar
Awesome!! I bet your daughter is loving it. I bet she will also have the boys swarming like flies to sugar.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-09-2013, 09:47 AM   #18
Fw190d9
Chuck, I know what you mean, Ive squealed the tires a few times test driving it.
Matt, She cant wait to get it back and yeah, Ive had to show quite a few boys the "Gun collection".
E.
Old 04-09-2013, 11:27 AM   #19
ls1nova71
ls1nova71's Avatar
Nice looking truck! Reminds me of my old blue truck with the 6.0 I sold a few years ago. Hope the cruise control install goes as smoothly as the engine swap. Hit me up if you have any questions.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-09-2013, 07:20 PM   #20
Fw190d9
Installed the Cruise control today, was an easy install. The hardest part was fishing the plug thru the flaming river steering column. Wired it up and it works great! Thanks Eric, great product. BTW, I need another one, scored another 72 C10 this afternoon. My Son is itching to get started on his 5.3 swap.
Evan Q.
Old 04-09-2013, 09:31 PM   #21
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Great looking truck...and yes...I'm guessing now you have a hp problem with your son!
I'm guessing maybe its just the angle of the pic....but it looks like you have 1/2" of clearance or less at the yoke, and this is while the wheels are hanging w/o supporting weight? Does it have enough room for the suspension to fully compress w/o bottoming the yoke?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-09-2013, 10:22 PM   #22
Fw190d9
Kurt, its the angle of the pic. Plenty of room all round the yoke even during full suspension compression.
Evan Q.
Old 04-09-2013, 10:52 PM   #23
Fw190d9
I also installed some "bling" for my little girl to enjoy while driving.
A full set of autometer Old Tyme gauges and a Kenwood Nav system to keep her from getting lost all the time.
E.
Old 04-10-2013, 01:47 AM   #24
jimmyjammoto
Beautiful truck and beautiful daughter! I can't wait to get my swap done; of course I don't think I could handle my girls driving it.. there has been a shortage of ammo lately..
Nice work again!
jimmyjammoto is offline   Reply With Quote
Old 04-12-2013, 11:13 AM   #25
truckdude239
truckdude239's Avatar
so you didn;t have to shorten or length the drive shaft?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
