My buddy has a 205 but needs a speedo gear. I have a spare 203 and was wondering if they would interchange or not before we tore into it since they're our dd's
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
60-66 Nut
Re: Np205 n NP203
Those both use different adapters. They will interchange as long as you have the correct adapter and both have the same input spline. Basically as long as both came from behind the same trans, they should bolt up. However your driveshafts may not. If the 205 just needs the speedo gear, I would fix that before I would go to all the trouble of switching the whole transfer case. The 205 is far better than a 203 anyway.
Tags |
203, 205, new process |
