Old 04-10-2013, 07:28 AM   #1
503swb
how much cfm carb for 454??
Im about to replace my carb on my 81 c10. I have a 454 in there. What cfm carb should i get? Im want an edelbrock carb.
503swb is offline   Reply With Quote
Old 04-10-2013, 07:41 AM   #2
naphtali5725
naphtali5725's Avatar
Re: how much cfm carb for 454??
need more info...
what cam do you have? headers? is this a daily driver? what are your driving habits? do you want fuel economy or more power?
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 04-10-2013, 08:45 AM   #3
B Barber
B Barber's Avatar
So many factors needed, so few given. 750 should suffice, but may not be needed. Im am not a fan of Edelbrock carbs, so I have no advice on which particular one. I ran a Holley 850 Street HP on my mild 468. It was a little more than I needed, but jetted it accordingly. We need more details.
V.P. of The American Squarebody Association.
1982 Sierra, 555 BBC, All Billet 700R4, Fab9 with 4.11's, Full 8.5 cert cage, 31x18x20 MT Sportsman S/R's on custom made 20x15 Amer. Racing Hopsters, 4-link with anti-roll bar and dual adj coilovers, Front drag shocks, Custom interior, and quite a bit more.
B Barber is offline   Reply With Quote
Old 04-10-2013, 09:20 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
I am running a 650 cfm on a mostly stock '74 454 witha SM-465 and 3.73 gears. So far it is working out ok, but I just use it as a driver. Throttle response is good and there is not the smell of unburned gas.
My grandson is running a 750 on a slightly modified 454 and it is working out real well.
My son is running a 850 on a highly modified 454 and he likes the way it is working.
Like stated before it depends on how the engine is built and how you drive it.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-10-2013, 01:55 PM   #5
503swb
Old 04-10-2013, 01:58 PM   #6
503swb
Honestly i dont know much about the engine as i haven't done anything to it. Im pretty sure the cam has been changed to bigger than stock. I currently have no headers on there but plan on getting some and it isnt my daily. I prefer more power over fuel economy. Hope that helps
Old 04-10-2013, 05:21 PM   #7
meatwagon83
meatwagon83's Avatar
put a 750 with vacuum secondaries on it, buy a secondary spring kit and put the black spring in it
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 04-10-2013, 06:15 PM   #8
b454rat
I have a mild 454 in my car with an Edelbrock 600. I needed a carb, buddy had one to use. I works OK, but trying to get money for a 3310. If it's stock or slightly above, a 600 will work fine. My last truck had a 600 and was friggin awesome. Only need a big carb if your gonna be turning high RPMs.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 04-10-2013, 06:38 PM   #9
Redcap
http://www.4secondsflat.com/Carb_CFM_Calculator.html
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 04-10-2013, 07:12 PM   #10
INSIDIOUS '86
INSIDIOUS '86's Avatar
Find any edelbrock carb on Craigslist and slap it on. They all run about the same.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-11-2013, 03:27 AM   #11
503swb
I was thinking of going with a 750 cfm
Old 04-11-2013, 05:02 AM   #12
andrewmp6
Try http://www.gtsparkplugs.com/CarbCFMCalc.html
Old 04-11-2013, 06:31 AM   #13
bigblock73
yeller
bigblock73's Avatar
I had a 750 Holley on my 454, it was too small...no matter what jets, squirters, cams or springs I put in there, could not get it to perform correctly. Just purchased an 850 double pumper, it should do the trick.
bigblock73 is offline   Reply With Quote
Old 04-11-2013, 07:21 AM   #14
BigBlocksRule
As long as it's mild, a 650 is fine.
Edelbrock carbs are old school, old tech. Get a Holley and let 'er eat.
BigBlocksRule is offline   Reply With Quote
Old 04-11-2013, 01:25 PM   #15
bammax
I'm running an e-brock 750 cfm on a Buick 455 at the moment. The factory carb for the big blocks back in the day was either 750 or 800 cfm depending on the make and year.
I personally love e-brocks since they don't have issues with leaking like q-jets and aren't as temperamental as holleys.
bammax is offline   Reply With Quote
Old 04-11-2013, 01:39 PM   #16
bansley
ci. x max rpm / 3456 ex. 454 x 6500 = 2951000 / 3456 = 853.87 cfm. I haved used this equasion many times and is very accurate. GOOD LUCK
bansley is offline   Reply With Quote
Old 04-11-2013, 01:55 PM   #17
bammax
Most calculators will say 725 cfm for a stock street vehicle and 950 or so for a race vehicle. The formula above basically splits the difference and is used as the general reference point to choose from.
I just go by what the factory put on it since that's what the intake manifold was designed to flow.
Also remember that smaller carbs generally have better throttle response but kill the top-end. I've seen people running 454's with 500 cfm carbs just because they're around town cars and never get rev'd above 4k rpms. I've also seen 1,100 cfm carbs used because the engine is running a 1/4 mile at a time and lives most of its life in a trailer.
Hopefully that info makes it as clear as mud for you
Old 04-11-2013, 10:08 PM   #18
meatwagon83
go ahead and run an 850 on a street 454, let me know when you get tired of horrible mileage no throttle response and fumes burning your eyes, now ask me how i know? mine has a 670 on it now and it is soooooo much better!
and a 6500 rpm redline in a 454? that motor would be borderline streetable at best! this guys max rpm is probably more like 5500, maybe! i have a .060 over 396 that has a 7000 rpm redline and my 850 dp was too much carb
Old 04-27-2013, 01:17 PM   #19
Redcap
It wrong. That is what you are doing.
Old 04-27-2013, 03:12 PM   #20
INSIDIOUS '86
No real builder follows that old 60s carb formula anymore. Also bigger carbs don't make your engine run richer
