Old 04-10-2013, 10:13 AM   #1
1972SUPERSB
1972SUPERSB's Avatar
Size of stock ram horn manifolds?
I am wondering what the size is of the stock ram horn manifold? I am thinking 2"? Is this correct? I want to run 2 1/2 exhaust and have the stock ram horn manifold. Will the 2 1/2 exhaust fit in these or will the pipe need to be increased when it comes out of the manifold to the new 2 1/2 exhaust? Thanks
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 04-10-2013, 11:05 AM   #2
JimKshortstep4x4
Re: Size of stock ram horn manifolds?
2" is the stock size. You will have to have an adapter to go from 2" to 2 1/2".
Ramhorns with 2 1/2" outlets are available.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-10-2013, 11:36 AM   #3
1972SUPERSB
Jim
Do they make the 2 1/2 ram horns with the angle outlet or just the straight down outlet?
Jeff
Old 04-10-2013, 04:25 PM   #4
MARKDTN
Only straight down. This was used on the 64 HiPo Corvettes. Even the later Corvettes used a 2" outlet and adapted up to 2 1/2" on the later ones that had the optional bigger pipes.
Another option for 2 1/2" straight down is 84-91 Corvette is a tubular shorty header and the 92-96 Corvette LT1 has a 2 1/2" outlet center dump cast manifold. If you buy LT1 ones, be sure to remove the cover before buying. They are prone to crack under the cover.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
