Old 04-10-2013, 10:14 AM   #26
oldman3
oldman3's Avatar
Re: 67 Rear axle bounce
Other info I forgot to post
#6569RACK 5 lug rear axles, complete kit (new drums etc) from CPP.
#6372SBK Heavy Duty sway bar kit (front and rear) from CPP.
The 3/5" drop kit we ordered came with the short adjustable trac bar not the long one.
If I find anything else I forgot, I will post it....Jim
oldman3 is offline   Reply With Quote
Old 04-10-2013, 03:42 PM   #27
broey
Square
broey's Avatar
I may have missed where you said this. But has the drive shaft been balanced?
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-10-2013, 04:44 PM   #28
ulakovic22
Have you tried driving it loaded and unloaded over the rear axle and then in front and behind? Also like Broey mentioned, carrier bearing and driveshaft balance.
ulakovic22 is offline   Reply With Quote
Old 04-10-2013, 04:57 PM   #29
oldman3
oldman3's Avatar
Drive shaft was cut down to work with the 4l60 trans and was balanced, with all new u-joints installed and new carrier bearing....Jim
Old 04-10-2013, 05:02 PM   #30
oldman3
oldman3's Avatar
Talked about this last night with a group of club members. I will try to get with owner and schedule a time to try this. Will cover the bed with lots of blankets and see if we can find bags of sand or something to use. Will post up something as soon as i can. This might tell us if the springs or shocks are wrong....Jim
Old 04-11-2013, 06:52 PM   #31
Hart_Rod
Hart_Rod's Avatar
I have a similar problem, so I'm going to tag along if you don't mind.
Hart_Rod is offline   Reply With Quote
Old 04-11-2013, 07:01 PM   #32
oldman3
oldman3's Avatar
Don't mind at all. If you have tried anything not mentioned so far, let's hear it, the more info the better, can't ever have to much.....Jim
Old 04-11-2013, 07:19 PM   #33
Hart_Rod
Hart_Rod's Avatar
I did everything you tried. I'm not sure where to go from here. Maybe bent axle tubes? Rear drums out of balance?
Old 04-11-2013, 11:28 PM   #34
oldman3
oldman3's Avatar
That's something that could be looked into, will let you know...Jim
Old 04-12-2013, 06:33 AM   #35
WBarlow
I had the same problem out of a 72 swb that I owned in mid to late 80's while in High School and in the military. Had a 350 with muncie four speed and had a drive shaft custom shortened by a "profesional". My truck did the same thing at high speeds around 70. I changed the drive shaft out and it stopped. I was told it was balanced, but there is no way it could have been. Are you running a straight drive shaft or swing bearing?
WBarlow is offline   Reply With Quote
Old 04-12-2013, 06:38 AM   #36
WBarlow
You'r problem may go away with a one piece drive shaft.
Old 04-12-2013, 06:50 AM   #37
jjzepplin
jjzepplin's Avatar
Had this happen once and it was my driveshaft. Now I always have them balanced and mark them before I remove them.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 04-12-2013, 09:13 AM   #38
68_chop_top
68_chop_top's Avatar
I just installed the shock relocator kit along with new KYB shocks. The ride was TERRIBLE! Bounced like a trampoline! I could not imagine the relocator kit was the problem so I swapped back to my old shocks. Problem solved. I am not going to bash the KYB shocks as the store refunded my money and returned them as defective. The old Nitto Drop 2 shocks I bought from CPP are back on and the ride is much improved thanks to the shock relocator kit.
May try and change out the shocks. The coil spring rear ends with drop spings and short shocks can sometimes work against each other and give you a bad ride. Easy enough to change out - try it.
You do very nice work!
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 04-12-2013, 09:28 AM   #39
Hart_Rod
Hart_Rod's Avatar
Good points by all. Jim can you post a video of what you are seeing? Also, do you get the same bounce at 50 MPH? 60 MPH?
Old 04-12-2013, 09:38 AM   #40
oldman3
oldman3's Avatar
It is a two piece drive shaft with center carrier bearing, all new parts and was balanced.
Old 04-12-2013, 09:41 AM   #41
oldman3
oldman3's Avatar
It is a two piece drive shaft with center carrier bearing, all new parts and balanced. Will try a few things, but may have to see about a one piece unit...Jim
Old 04-12-2013, 09:45 AM   #42
oldman3
oldman3's Avatar
As soon as I can get with the owner, we are going to try putting weight in the bed, if this works, then we have to figure out the shock problem. I've been reading about mono and twin tube shocks, not sure what type is on the truck now. Thanks about the work....Jim
Old 04-12-2013, 09:47 AM   #43
oldman3
oldman3's Avatar
It's been hard getting with owner to do all of this, but I would like to get a video, havent' checked it at 50 or 60, will have to do that also....Jim
Old 04-13-2013, 03:53 PM   #44
Slow Build
Slow Build's Avatar
Have you tried rotating the rear u-joint connection 180 degrees? Somewhere in the back of my mind I think I remember someone doing this and it helped.
Also it must be an optical illusion but it looks like your rear driveshaft is lower at the center bearing than at the rear end. I've never had a two piece drive shaft so I don't know what kind of considerations you would have for angles at the center bearing but since the angles between the tranny and the center bearing are basically fixed I would think the angle from the rear of the bearing and the rear driveshaft might be important.
I'm just throwing it out there. Don't know if it's relative or not
Good luck
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-14-2013, 12:00 AM   #45
oldman3
oldman3's Avatar
Slow build, think it is just the picture. Rear driveshaft is actually level from center bearing back to housing. Pinion angle is 3 degrees up. Can try rotation the drive shaft and see if it makes difference, thanks....Jim
Old 04-22-2013, 08:40 PM   #46
oldman3
oldman3's Avatar
Just wanted to let you guys know that I still haven't been able to set up time with the owner. His wife is due real soon with their baby. As soon as we come up with anything I will post it up....Jim
Old 05-18-2013, 11:19 AM   #47
68_chop_top
How about now?
Old 05-18-2013, 02:35 PM   #48
oldman3
oldman3's Avatar
How about now?
Nothing yet, he still hasn't been able to get with me for any testing, etc.. Hope to within the next month, his wife hasn't delivered yet....Jim
Old 05-18-2013, 02:45 PM   #49
Dunenutt
Newbee
Dunenutt's Avatar
Have you checked to see if the drums are balanced? I had a bad one on my dually, and it drove me crazy.
Dunenutt is offline   Reply With Quote
Old 05-18-2013, 02:48 PM   #50
oldman3
oldman3's Avatar
That's one thing I have not checked, will add it to this list, thanks...Jim
