Old 04-10-2013, 02:46 PM   #1
jesseo
jesseo's Avatar
Switching to gauge cluster
I am switching out my gauge cluster from the warning light cluster to the actual gauges. I have a wiring harness on order. Looking to find the correct oil and temp sending units. Can I pull from a newer 350 I have? Would they still read correct?
jesseo is offline   Reply With Quote
Old 04-10-2013, 02:53 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Switching to gauge cluster
Your oil pressure uses a presure switch, they are the same I believe but will see what the others say, you will need the correct temp sender, you can get them thru Truck and Car Shop...page 93 in the online catalog.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-10-2013, 03:17 PM   #3
jesseo
jesseo's Avatar
Thx. haven't ever been to that site. It is awesome.
Old 04-10-2013, 05:29 PM   #4
QBA
Proud Americano
uhmmm....the oil gauge is mechanical.it takes a line from the engine to the oil gauge.
the temp senssor can be had at a napa or autozone.
hope this helps
Tattooed Cuban Trailer Trash.
putting the cart before the horse since 1964.
QBA is offline   Reply With Quote
Old 04-10-2013, 08:35 PM   #5
1963c-10
1963c-10's Avatar
hope this helps
x2, plumb from the engine directly to the oil guage
1964 Short bed trailer
Old 04-11-2013, 09:46 AM   #6
MikeN
MikeN's Avatar
I had no luck getting my temp gauge to read accurately with parts house sending units. Based on a tip I got on the Team Chevelle website, I got sending units from these guys..
http://www.lectriclimited.com/
and the factory temp gauges now work perfectly in both my 69 Chevelle and my 64 C10.
MikeN is offline   Reply With Quote
Old 04-11-2013, 11:05 AM   #7
jesseo
jesseo's Avatar
Thx Mike this helps a lot. Got a temp sending unit on order and the oil pressure unit is the same as on my 350 engine. mechanical. This is perfect. Again thx Mike.
Old 04-11-2013, 11:09 AM   #8
1963c-10
1963c-10's Avatar
Make sure not to use teflon tape on the temp sending unit. I got mine from classic parts 3 years ago...no issues.
Old 04-11-2013, 11:31 AM   #9
jesseo
jesseo's Avatar
thx I probably would have put some on. I love me some teflon tape.
