04-07-2013, 12:24 PM | #51 |
Re: how much horsepower does your truck have
stock 350 hp / 327 with m21 & 12bolt / 3:73's. It can be a handfull on wet streets here in Seattle. First gear can be tricky, but 2nd scares the hell out of the local ricers.
04-08-2013, 04:49 PM | #52 |
stroked 396 BBC about 500 ft/pounds of torque.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
04-08-2013, 05:06 PM | #53 |
How much horsepower? Well, I could probably pull three horses with the right trailer if it had electric brakes.
I've got a mild 302 with a 350/327 cam and small heads. I'm lucky if it's near 270 at the wheels. I disagree with the idea that you can't have too much power. This truck is mostly stock and it already has more go than stop, and more push than turn. Yeah, I built a lot of vehicles like that when I was a kid. But these days I realize luck probably kept me alive more often than skill. Keep the power level appropriate for the chassis and the area you're driving. |
04-08-2013, 05:36 PM | #54 |
I just picked up a LQ4 yesterday and plan on giving it a mild stroke to 408 depending if it needs boring. The LS motors have a lot of interchange parts. I'll put on L92 heads and a LS3 intake with the MSD Atomic LS EFI system to get rid of the rats nest of wiring harness. Behind it will be a 4L80 and Dana 60. I'll be towing a Jeep over the mountains and want to have enough power. That's my story and I'm sticking to it. At least to my wife.
Posted via Mobile Device |
04-08-2013, 06:51 PM | #55 | |
they had 5 completely different numbers that varied as much as 85 hp. on top of that there was as much as 50 hp difference between pulls on the same dyno. truk had a '74 302 in it that was donated to my son's 68 elco. it was factory rated at 140 hp, that was at the crank i roll my eyes when i hear anyone claim to have more than 1 hp/cubic inch in a pre Lx motor unless your building a kabwe build with big old meats on back our trucks will only spin the tires anyway
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-08-2013, 07:48 PM | #56 |
1974 truck 4 bolt 350 bored to 355 ci. Has a cam, aluminum intake, Qjet, ram horn manifolds. Stock it is listed as 160hp and 250tq, so maybe 200 with the cam and improved intake?? Previous 283 w/ 292 cam and 4 bbl did fine, I am hoping this motor will have a little more low end torque.
04-08-2013, 07:59 PM | #57 |
I know I will have more horsepower than I need. Running an automatic will help keep the tires on it. The big difference will be the modern EFI. We'll be living at 7000 feet starting next spring. I'll be towing from 0 to 10,000 feet so the extra power will be nice. Hopefully the 4L80 will be able to hold together.
The price on the LS truck motors is about the same no matter what the size except for the lone big block. For $800 it was hard to pass up on a complete 6.0 vs. the smaller sizes that sell for the same amount or more. Posted via Mobile Device |
04-09-2013, 12:45 AM | #58 |
Mine has one gazillion horsepower. Makes it go plenty fast enough for me.
Retired and too busy to work. |
04-09-2013, 10:53 AM | #59 |
Not enough
04-09-2013, 11:46 PM | #60 |
Okay, maybe it 10 gazillion, I forget.
04-10-2013, 12:32 AM | #61 |
250 inliner bored .040, healthy cam, milled head, rechambered, lump ported, Z28 dual springs, 202 intakes, balenced etc running a heated clifford 6=8 with a Holly 390, stoveboltengines cast headers into 2.5 inch all the way out. MSD HEI with 10mm Live wires a K&N filter and it gets 20 mpg highway, has enough torque to pull our camp trailer and supposd to be a 200 hp combination wich is enough for me .
04-10-2013, 07:55 AM | #62 |
330 bhp from a crate 350........but with an open diff, it does this most of the time
04-10-2013, 09:56 AM | #63 |
My 6000# Avalanche has a 5.3L w 4L60E, GearVendors & 4.10 gears - Plenty of GO
My 4500# SSR has a 5.3L w 4L60E & 4.10 gears - even more GO My 3500# 57 GMC has a 5.3L 4L60E, GearVendors & 4.11 Gears - Way MORE GO if it hooks when I get it on the road. What I'm saying is power to weight ratio and traction are key to how much is to much.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 Last edited by G&R's57GMC; 04-10-2013 at 10:05 AM. |
04-10-2013, 10:32 AM | #64 |
I have no idea what mine would dyno at but it is a 350 with flat top pistons, camel hump 2.02 valve heads and a decent cam. 700R4 tranny and 3.73 gear with 29x15.5 tires. Hooks up great with the 4 link. Plenty of power for the street and cruises down the highway all day long with no issues. Also does a pretty good burn out but tires ar just too expensive for that.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
04-10-2013, 10:58 AM | #65 | |
04-10-2013, 11:09 AM | #66 | |||
Boosted Member
No. Quote:
I drove 150 miles in the pouring rain on PowerTour a couple years ago, on bald drag radials, with ~500 rwhp. No drama. 400 hp is barely adequate, IMO. But I'm a HP junky. Quote:
[EDIT: Sorry, just noticed this was in the 47-59 section...hit "new posts" and assumed it was in the "racing and performance" section...if you can fit the tires, use them]
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 04-10-2013 at 11:22 AM. |
04-10-2013, 11:17 AM | #67 |
Boosted Member
As far as power, with the stock 5.3 (at the time) and a smallish turbo, my '69 C10 was ~500 rwhp judging by trap speed.
More than enough to hang with and beat "supercars", and still drive to work. The viper edged me out this run (although I was reeling him in) but I got him later that night. My setup in the blazer will be around 800 rear wheel hp. Hooking that one up will be more of a challenge.
04-10-2013, 01:22 PM | #68 |
Traction is key to Power
My 4200# 56 GMC Suburban Pick up w 389 Ponco & 4 speed Hydramatic w 3.55 open Diff just smokes the 1 tire and goes no where, All that power and no go. Once rolling torque does all the work at lower rpm in this truck. Besides anything over 70 MPH is just too noisy and sucks fuel. Damm, I must be getting old
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
04-10-2013, 07:38 PM | #69 |
My 383 motor is around 480-500hp. Should be fun on airbags & 4 link and skinny 245 tyres and a LSD ( positrack ) it is being build for a cruiser that when i want can step on it and get some smoke happening.
Blake. Sydney Aus 56 Chev 3100 build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363 LOW n LOUD |
04-10-2013, 07:49 PM | #70 |
(insert eye roll here)
(insert dyno sheet here)
04-10-2013, 07:53 PM | #71 |
hahaha
That is on a engine dyno* once its in the truck i will get some real numbers at the wheels, but i have paper and a video so i will upload it when i can.
04-11-2013, 12:27 AM | #72 |
What does a Stock 1959 GMC 100 have ?
1971 GMC Sierra 1959 GMC 100 |
04-11-2013, 11:14 AM | #73 |
I've got most of the pieces for a .040 over 396 that was going in the 48 but it will get the 68 292 with not a whole lot of horsepower.
My 57 Panel had a 327 with 12.5 Jahn's Pistons, Engle solid lifter cam and 202 heads with a Corvette Dual 4 setup on it and it would pull the front wheels when launched hard but I got tired of constantly having to work to keep it tuned to the max. I have no idea of the horse power but it would stay with a 750 Honda bike for a city block in a street race. These days I am more interested in having the 48 set up as a reacher that can burn up highways for hours on end to far flung places.
04-11-2013, 11:48 AM | #74 |
My 59 has an early 327 in it. Not much power, but i wouldn't change a thing. Its only a cruiser anyway.
04-11-2013, 12:56 PM | #75 |
the 327 was the first gm motor available with 1 hp per cubic inch
not sure what yrs that was available, i bought a 67 camero with a 327/327hp truk had the 140hp 350 in it when i bought it in the 80s, even then it was a tire smoker these trucks are very lite, especially out back
