Old 04-11-2013, 08:38 PM   #1
goose_on_fire
What's going on here with my rear suspension? (pics)
Couple of pics to set the stage ('69 C10 long step).
I'm looking at the chassis service manual and noting that auxiliary leaf springs were an option on a '69 C10, but what I'm seeing here ain't matching the picture in the book...
Yes, those are blocks of 2"x2" wood in the chassis (to prevent it from collapsing from those u-bolts?!), and the rubber pad bouncing against the control arm.
So I'm guessing this is in no way stock, but wondering how bad an idea it is, how lame it is, whether it could possibly do any good at all, etc. I'm new to these trucks.
Thanks for the help!
goose_on_fire is offline   Reply With Quote
Old 04-11-2013, 08:46 PM   #2
Street Smart
Street Smart's Avatar
Re: What's going on here with my rear suspension? (pics)
Pretty creative... to say the least. Factory aux springs were mounted behind the axle.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 04-11-2013, 09:16 PM   #3
mac808
mac808's Avatar
What the...??? I've never seen that before. Was that an actual part or suspension set up back then....???
mac808 is offline   Reply With Quote
Old 04-11-2013, 09:43 PM   #4
SS Tim
SS Tim's Avatar
It looks like it was an aftermarket kit and the wood was added in. If you have weak stock springs they might be doing something. Best thing to do would be to use factory C10 HD coil springs (or a replacement) and pull these off. But if you are not planning on loading the truck down a set of std rate coil springs are also a good choice.
SS Tim is offline   Reply With Quote
Old 04-11-2013, 09:45 PM   #5
cdowns
cdowns's Avatar
pretty common straus store jc whitney pepboy sears monkey wards type generic overloads from back in the day
Old 04-11-2013, 09:59 PM   #6
giles70chevy
giles70chevy's Avatar
My frame had the same setup on it when I got it. Sorry I don't have any pics to compare to yours. I junked them when I disassembled the truck late last year.
giles70chevy is offline   Reply With Quote
Old 04-12-2013, 04:11 AM   #7
mac808
mac808's Avatar
Tell us what you really think about these contraptions
Old 04-12-2013, 05:55 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Looks like they're doing you some good. See how the factory coil springs have settled down to where the add Ons are nearly touching and you don't even have the weight of bed wood in there. I'd bet if you put a new pair of coil springs in the truck that it would raise up enough to where the helper springs are much further from the trailing arm.
I think they're pretty neat. I'd leave them there just for kicks. They won't affect anything until you load the truck down and then they'd be doing what they're intended to do.
Tx Firefighter is offline   Reply With Quote
Old 04-12-2013, 10:03 AM   #9
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
As Tx said,I would replace those rear springs.They look fully collapsed with no weight on them.
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 04-12-2013, 11:44 AM   #10
hockeyjerk1
hockeyjerk1's Avatar
I have the same on mine and they work great, the stock springs are can't carry much.
hockeyjerk1 is offline   Reply With Quote
Old 04-12-2013, 01:09 PM   #11
goose_on_fire
Awesome, thanks for the feedback and opinions. If nothing else, replacing those coils is now definitely on my to-do list.
Old 04-12-2013, 10:11 PM   #12
goose_on_fire
I also noticed today that the e-brake cable is rubbing up against those u bolts, you can see the smears in those pictures.
I'm assuming I should do something about that while I've got everything torn apart?
