Old 04-12-2013, 09:41 PM   #1
Leonard1
Leonard1's Avatar
Fuel Tank Setup
Hey guys, I guess I should have posted this here to begin with, but does anyone see any problems with my fuel setup?
My New Underbed Fuel Tank
Leonard1 is offline   Reply With Quote
Old 04-13-2013, 08:20 PM   #2
jorgensensc
jorgensensc's Avatar
Re: Fuel Tank Setup
What are the dimensions of the tank itself?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-13-2013, 10:03 PM   #3
Leonard1
Leonard1's Avatar
Re: Fuel Tank Setup
I think it's 28-3/8" x 28-1/8" x 10-3/4" deep. It fits between the frame rails either way you turn it.
Old 04-14-2013, 10:00 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Fuel Tank Setup
This probably isn't a life or death concern, or may not be a concern at all; the galvanized steel retains no rust protection once welded and the galvanized coating is worn back. I'd be a tiny bit concerned that you could run the risk of getting a little rust into the tank.
A little primer and paint on the outside of the weld will handle that, though I'm not sure about the INSIDE of the tank. Again, this is a miniscule issue, as a pre filter would take care of any particulate that would drop in...but I'm playing devils advocate. IMO theres a reason that fuel cells and aftermarket tanks are usually plastic or stainless.
As for the amount it hangs down, 9" is a bit much, but it depends on how low you plan on setting the ride height. On my 66, the fuel cell hangs down about 6-1/2". It's still well above the rear end at ride height, but still makes me nervous if driving on really uneven surfaces.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-14-2013, 07:58 PM   #5
Leonard1
Leonard1's Avatar
Re: Fuel Tank Setup
Thanks for the replies. I didn't think soldering would remove the galvanization? I intend to paint the exterior of the tank, but I was going to leave the inside as-is.
Old 04-15-2013, 12:43 PM   #6
kevinc
kevinc's Avatar
Re: Fuel Tank Setup
Be careful welding with galvanized metal. It releases a toxic gas so be sure you're well ventilated.
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 04-15-2013, 04:29 PM   #7
thotfulspot
Re: Fuel Tank Setup
Eastwood makes a gas tank sealent I've used on a rusty tank and it sealed it up. I'm sure you could use it on a new tank.
thotfulspot is offline   Reply With Quote
