Old 11-18-2003, 02:00 AM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Big block head ID...
I think it says 8993820.
boat anchors?
some one said he had the casting list and would decode...just can't remember who it was.
Yeah...I suffer from CRS.
Old 11-18-2003, 02:05 AM   #2
frost89434
frost89434's Avatar
are you sure it's not 3993820.
3993820....71-84...oval...OPEN...454 Passenger and Trucks, 113cc chamber, Jim
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 11-18-2003, 02:08 AM   #3
Longhorn Man
Ok...I suffer from CRS and sloppy notes.
So are these heads any good ona smaller big block...a 396/402? (still don't know which it is)
Old 11-18-2003, 02:10 AM   #4
frost89434
frost89434's Avatar
I am not really good with big blocks so someone else would probably be better help than I would. JIM
Sparks, Nevada
Old 11-18-2003, 03:07 AM   #5
68c10owner
68c10owner's Avatar
some say the 820 heads are junk, some say they are ok. if i remember correctly, they are a smog head. they are similar to the 049 castings. the 820 heads are decent street heads. they are open chamber so on a 396/402, you won`t get much more that about 9 to 1. to get more compression from a 396/402, you need custom pistons or use high compression closed chamber pistons. you loose about 1 point of compression going from closed to open chambers.
Anthony
68c10owner is offline   Reply With Quote
Old 11-18-2003, 12:10 PM   #6
redbowtie
3993820 1971 402...300, 330 hp LS-3 Open 113.0cc
454...365 hp LS-5
There's better BB heads, but these will make some decent HP for a semi-mild motor.
LS-5's were no slouches...
redbowtie is offline   Reply With Quote
Old 11-18-2003, 12:18 PM   #7
LeRoy
Registered truck nut
LeRoy's Avatar
Have you check out this site. Don't know if that's what your needing or not. http://www.mortec.com/
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 11-18-2003, 03:10 PM   #8
junkyarddog1956
junkyarddog1956's Avatar
I looked all through Hollander and could not find that casting # ... I have to go to the machine shop this afternoon and will ask him if he knows .... jyd
69 Chev C-10 ... painted and ready to reassemble ( for sale )
82 Custom Deluxe ( have parts to restore )
junkyarddog1956 is offline   Reply With Quote
Old 11-19-2003, 07:25 PM   #9
bow-tie-bandit
Live life and be happy.
bow-tie-bandit's Avatar
Looked in the Production Engine Remanfactures Association book and those heads are listed in the chevy v-8 passenger section and say year 1972-68, cid 400-396, litre 6.6, bore 4.125, Description Big Block. It also lists 3969854, 3931063, and 3964290. Hope this helps.
bow-tie-bandit is offline   Reply With Quote
