Closed Thread
Old 04-14-2013, 12:26 AM   #6601
PAWS 72
PAWS 72's Avatar
Re: What did you do to your truck today!
some more
PAWS 72 is offline
Old 04-14-2013, 09:49 AM   #6602
Boog
laying low
Boog's Avatar
Nice shots Paw. Are the stepside owners, by chance, forum members too?
Those look like TruSpoke wire wheels on the GTO. I would never have thought to put those together but I like it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 04-14-2013, 09:50 AM   #6603
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks for the pictures Paw, Awesome shots
Love that Bug
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 04-14-2013, 10:01 AM   #6604
VWNate1
VWNate1's Avatar
Post Re : Power Steering Service
RE : the 4th.P.S. Pump in 4 years ;
The fluid is polly contaminated in spite of your changing it with each new or rebuilt pump .
Give it a sniff , if the fluid smells like burnt coffee , it's bad .
I like to buy a gallon or two of bulk Dexron and flush the system , it's simple : disconnect the return hose and put it in a large jug , cap off the nipple on the pump , fill the system and have a funnel in the pump and the new gallon of ATF in your hand, have your helper start the engine and as the pump rapidly (you'l be amazed at how rapidly) pumps itself empty , you fill the resivoir as your helper turns the steering wheel lock to lock , of course the front wheels must be off the ground , this will flush out the nether regions of the entire PS system, the box , spool valve and so on .
Then stop the engine and re connect the hose , fill the resivoir until the ATF *just* touches the bottom of the dipstick , it'll expand a lot (10% minimum) once it's good and hot .
I hope you know to use Dexron ATF in the power steering .
Also , never , EVER hold the steering against the stop ! this is what causes the fluid to rapidly overheat and burn plus it also beats the living hell out of the PS Pump .
I often find I have to flush the PS system several times before the fluid remains sweet smelling .
I always use a hospital clean drain pan and look closely at the old fluid , if there's any shiny bits in there , get a Rare Earth Magnet and place it inside the resivior to collect the metal swarf that's been killing your pumps .
In some of my old junkers it's taken over a year and 6 + flushes before the fluid stopped turning black & stinky after a month of operation .
As always : oil is the cheap Mechanic and easier to change than steering parts .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 04-14-2013, 11:23 AM   #6605
67Slider
67Slider's Avatar
Re: Re : Power Steering Service
Great Idea. Never thought of doing it that way
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 04-14-2013, 11:44 AM   #6606
PAWS 72
PAWS 72's Avatar
I cant get anymore owners on here. I tell them about the board all the time but none has ever joined.There is about 4 from my area but alot of trucks.
I even tell some of the other generation truck owners about it but...
PAWS 72 is offline
Old 04-14-2013, 11:48 AM   #6607
Mr.Hyde
well here in winnipeg we still have snow... so ive been fighting to get my cab and bed home.
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline
Old 04-14-2013, 11:52 AM   #6608
PAWS 72
PAWS 72's Avatar
Heres a few more.The last one is a friends daughter.She had a ball with daddy last night.
PAWS 72 is offline
Old 04-14-2013, 02:25 PM   #6609
SCHRUMGMC
SCHRUMGMC's Avatar
Beautiful Yellow bug
1971 GMC Sierra
1959 GMC 100
Old 04-14-2013, 02:32 PM   #6610
in deep 72
in deep 72's Avatar
Made a shroud for the new electric fans. This should finally keep things cool! Bent up some new trans cooling lines and the fuel line from teh pump to the carb.
Also added a "lift kit" to the carb. HAHA
in deep 72 is offline
Old 04-14-2013, 02:34 PM   #6611
ozzy3636
Originally Posted by sjarrett71 View Post
1st post ever was about winning an award and you don't post pics?!?!?! What's up with that?
BTW, welcome to the board!
Sorry here is the truck and the award
ozzy3636 is offline
Old 04-14-2013, 02:58 PM   #6612
SCHRUMGMC
SCHRUMGMC's Avatar
I love the GMC Grills back when
1971 GMC Sierra
1959 GMC 100
Old 04-14-2013, 03:02 PM   #6613
ozzy3636
Yeah I love that grill makes it stand out
ozzy3636 is offline
Old 04-14-2013, 03:03 PM   #6614
SCHRUMGMC
SCHRUMGMC's Avatar
I like them better then the Chevy's
1971 GMC Sierra
1959 GMC 100
Old 04-14-2013, 03:04 PM   #6615
ozzy3636
Yeah me to
ozzy3636 is offline
Old 04-14-2013, 03:06 PM   #6616
SCHRUMGMC
SCHRUMGMC's Avatar
I miss my 71 GMC SWB..White top and blue body..I may get it one day
1971 GMC Sierra
1959 GMC 100
Old 04-14-2013, 03:57 PM   #6617
dirtyjim
dirtyjim's Avatar
Replaced a lower ball joint & two tie rods.
If I have time this afternoon I'll finish hooking up the radiator overflow
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline
Old 04-14-2013, 09:42 PM   #6618
longbed67
longbed67's Avatar
Mocked up my gooseneck plate and fab'ed up some shock re-locators that still use the oem shock size
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline
Old 04-14-2013, 10:55 PM   #6619
buckskins4ever
buckskins4ever's Avatar
I took the plunge and decided to list mine for sale. Got another toy in sight....and momma says one has to go before hand. Argh!!
buckskins4ever is offline
Old 04-15-2013, 12:54 AM   #6620
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Been working on getting mine broke out of mothballs, figuring out what needs done.
Made a video:
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline
Old 04-15-2013, 01:05 AM   #6621
PAWS 72
PAWS 72's Avatar
Attachment 1092179
Attachment 1092180
Congrats.Welcome to the board.
How wide are the rims. I'm taking my son's rims off his truck that are the same one's and putting them on mine. He's tired of the wide wheels.
PAWS 72 is offline
Old 04-15-2013, 01:20 AM   #6622
78bronzechariot
78bronzechariot's Avatar
Gapped the doors and fenders to prep for bodywork. Body worked the spoiler a little bit.
78bronzechariot is offline
Old 04-15-2013, 07:31 AM   #6623
SCHRUMGMC
SCHRUMGMC's Avatar
great progress
1971 GMC Sierra
1959 GMC 100
Old 04-15-2013, 09:10 AM   #6624
midniteblues
midniteblues's Avatar
finished up my ds corner & rocker all went well..... an i'm allready on too the ps side
thank god i got 90% of the hidious black paint off the cab an doors but there is still alot of black left on all the other body panels(no offense to anyone one with a black truck but flat black is just not for me)I'll be picking up some primer & green paint in the next couple weeks
oh an speaking of nasty black paint I sprayed my rad support over the weekend an it came out good.....slowly coming together
i wanna thank member mighty mouse for the core support
its was a hell'va buy for such a nice part that is about impossible too find in good shape around here
thank you thank you
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 04-15-2013, 12:18 PM   #6625
71sixgun
Installed new cap, button, plugs and wires today. Changed the oil and filter. Idles so much smoother now!! Progress is looking great midnitebles!!!
71sixgun is offline
Closed Thread
