Old 04-15-2013, 08:59 PM   #1
Stroked10
Stroked10's Avatar
Cold spark plug.
I am about to change the spark plugs on my truck. Since I bought the truck already built I have no clue on engine compression, cam etc. So I bought the ones that were on the truck (r42ts) anybody running these? Research shows they are really cold.
Mods on the truck that I could see.. 383 stroker, edelbrock performer, edelbrock weber 600 cfm (I think) 4 barrel carb, headers, cam ( small they told me) accer super coil, msd wires. Any other plugs you guys recommend? And what gap?
Stroked10 is offline   Reply With Quote
Old 04-15-2013, 09:19 PM   #2
Rufton
Re: Cold spark plug.
I recommend the coldest plug that will work w/o forming deposits on electrode. I buy the cheap plugs in three heat ranges to determine how low I can go.
Rufton is offline   Reply With Quote
Old 04-15-2013, 09:31 PM   #3
mongoose
mongoose's Avatar
slap in a set of ur4's.. if it doesn't ping keep them in if it does swap them out... to ur5's or the 42's.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-15-2013, 09:50 PM   #4
Stroked10
Stroked10's Avatar
I'm not sure what ping feels like.. If I step on the truck really hard while on the move it will almost like neutralize, then move if I let go of some gas, don't know if its related to the plugs. I pulled cylinder 1 plug and it looked perfect.
Old 04-15-2013, 11:06 PM   #5
willett
Another Day, Another Dollar
willett's Avatar
That sounds like something accelerator pump related possibly.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 04-15-2013, 11:28 PM   #6
Rufton
Ping at any speed is not engines friend. Ping at WOT can damage engine in short order.
Old 04-16-2013, 12:01 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Ping at any speed will do damage if prolonged. This will sound like pennies bouncing in the engine
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-16-2013, 12:26 AM   #8
Stroked10
Stroked10's Avatar
Oh ok.. Never heard that sound like pennies bouncing.. I actually thought it was the transmission slipping and neutralizing. I will do a search on the accelerator pump. First carburated car . Thanks for the help guys, awesome forum!!
Old 04-16-2013, 01:03 PM   #9
Rufton
The accelerator pump squirts a few drops of gas inside venturi each time you press accelerator. You can watch the fuel squirt if look into carb (look when engine is OFF) while stroking accelerator linkage. Often linkage to accel pump has 3 holes to adjust how many drops are squirted in. Over time the rubberish accel pump piston seals harden and need replacing. The accelerator pump can easily be serviced on many carbs in a couple minutes w/o removing carb; may have 4 screws.
Old 04-16-2013, 05:15 PM   #10
Stroked10
Stroked10's Avatar
Ok so I tried to see fuel squirting but couldn't. I hear and smell it though. Here's a few pics, found out the carb I have is an edelbrock 1806s, 650 cfm. It looks pretty dirty, how would I go about cleaning it?
Also the linkage is on the middle hole should I put it on the top hole?
Old 04-16-2013, 05:17 PM   #11
Stroked10
Stroked10's Avatar
Thanks. I think I'm gonna buy this one http://www.amazon.com/gp/aw/d/B00062YA7G http://www.amazon.com/gp/aw/d/B00062YA7GPosted via Mobile Device
Old 04-16-2013, 05:43 PM   #12
Rufton
You pick the acel pump hole which makes car react best to brisk pedal push.
Of course it won't pump anything if the well is dry.
If you can hear and smell it you should be able to see it. On many 4BBL the fuel squirts out in two streams into primaries.
Old 04-16-2013, 05:50 PM   #13
Stroked10
Stroked10's Avatar
Ok I'm gonna try the top one and post back.. Thanks for the help.
Old 04-16-2013, 05:53 PM   #14
Rufton
You have to remove the entire top of edelbrock to change pump.
Tips:
Read edelbrock manual.
Tie dental floss to small clips for easy removal w/o loosing.
Don't remove floss till clips safely at home.
Loosen but don't remove rod covers.
Remove rods/springs before removing top.
After loosening all top screws bump top back and forth w/ hand before pulling off in effort to save top gasket.
Check float and jets while top off.
Lube new accelerator piston seal before installing.
Don't drop your grills into intake.
Old 04-16-2013, 05:54 PM   #15
Stroked10
Stroked10's Avatar
Ok awesome advice!
Old 04-16-2013, 06:14 PM   #16
Rufton
Thanks. I have an edelbrock and really like it. Can buy many jet sizes for all kinds of tuning. Rebuild is almost fun. Makes my engine run great. Get pretty good AFR per wideband O2 gauge. Some like berryman B12 chemtool for cleaning.
Old 04-17-2013, 07:30 PM   #17
Stroked10
Stroked10's Avatar
Just to update.. I moved the linkage to the upper hole and there's no more neutralizing under hard acceleration!!!.. Thank you guys for all the help.
Also all 8 spark plugs look good not going to change them yet. If it ain't broke why fix it.
