Old 04-16-2013, 12:39 AM   #1
Jyman
What did you end up doing?
Ok I tryed the search funtion but couldn't find what I was looking for. I was wondering what everyone was doing for your E-brake? I thought about using the set up from a S10 but it just hangs much to low below the dash. So if you could post a picture and tell me what it was from, That would be awesome and maybe help me solve my problem.
Thank you everyone, for your help.
1948 Chevy
305, NV3500, 3.73 rear, sitting on a 95 s10 frame. Still in the works
2000 Chevy Extreme lowrider, 4.3, NV3500, 3.08 rear, upgraded/modded
2001 GMC Sonoma Zr2, 4.3, NV3500, Stock
Jyman is offline   Reply With Quote
Old 04-16-2013, 02:18 AM   #2
N.T.Q
Re: What did you end up doing?
I used one from a 2001 Chevy cavalier if you are running buckets it fits perfect
N.T.Q is offline   Reply With Quote
Old 04-16-2013, 05:42 AM   #3
S10Fan
Old Heap Driver
Nothing right now, and yes, I do plan to add one. Since my seat situation has finally been decided (62 4-door Jag front buckets), I'll probably end up using a garden variety center mounted piece.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-16-2013, 07:38 AM   #4
2ndGenRR
2ndGenRR's Avatar
The S10 frames run the brake lines up the driver's side, so a center floor mount is hard to adapt. Trust me I tried, and everything is in the way of running the cables. I ended up using a hand operated lokar under dash handle, which allows you some flexibility in mounting.
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 04-16-2013, 09:43 AM   #5
solidaxel
solidaxel's Avatar
All my trucks have the stock E brake and Control Cables Inc. has made all the rear cables for the different rear axels, works great!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-17-2013, 01:32 PM   #6
mobileortho
mobileortho's Avatar
I'm using a Lokar setup.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 04-17-2013, 03:32 PM   #7
SCHRUMGMC
SCHRUMGMC's Avatar
I may need one in my 59 some day
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-17-2013, 06:59 PM   #8
Speedbumpauto
Speedbumpauto's Avatar
I used Lokar also, in spite of their annoiances. They have everything to make it work, it just costs money. I mounted mine at an angle on the floor for a kind of old time look. Had to do some re-engineering but I like it. Unless state inspection demands it, for an auto trans, I'd probably never install one....but I did.....again!
Speedbumpauto is offline   Reply With Quote
