04-16-2013, 01:53 PM | #26 |
Re: Overbuilding - Looking for advice on how not to
As Low Eco mentioned, I found the Make It Handle Thread, read the entire thing and then started researching around in the Suspension Forum for a long time
So next to come was the rear suspension With everything stripped out of the rear frame for the axle rebuild I went ahead and flipped my stock trailing arm brackets to raise the pivot point of the arm and have it act more like factory geometry etc.. I also stich welded my factory trailing arms to stiffen them up more and installed new poly graphite bushings from Early Classic Enterprises Info here: Post 270 - http://67-72chevytrucks.com/vboard/s...419251&page=11 http://67-72chevytrucks.com/vboard/s...d.php?t=439768 And a really good post in Gringoloco's build thread of the effects of the flip: http://67-72chevytrucks.com/vboard/s...444746&page=37
'68 SWB Stepside - Inline Long Six 250 C.I. (LS250): http://67-72chevytrucks.com/vboard/s...ferrerid=83901 |
04-16-2013, 02:07 PM | #27 |
Continuing the Rear
I went with a Shock Re-locator from No Limit Engineering (Rob here on the board) : http://67-72chevytrucks.com/vboard/s...d.php?t=444928 The Panhardbar kit from No Limit: http://67-72chevytrucks.com/vboard/s...=436621&page=7 C-notch from Porterbuilt : http://67-72chevytrucks.com/vboard/s...d.php?t=405754 2" Drop Blocks and 4" Springs to start with (I later swapped to 6" springs to level the ride height better)
04-16-2013, 02:11 PM | #28 |
Now because I went with two different brands/suppliers on the rear suspension I did hit a snag with the installation but was able to find a solution:
You can see from the pictures what the issue was and what the final outcome was Details are here: http://67-72chevytrucks.com/vboard/s...d.php?t=507982
04-16-2013, 02:13 PM | #29 |
Nice fix!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
04-16-2013, 02:38 PM | #30 |
Heres a shot of the suspension mocked up with the 4" Springs and 2" blocks
And then a shot with the bed just resting on the frame From here I decided to go with a 6" drop spring and I had to machine my drop blocks to match the pinion angle so they lost alittle height
04-16-2013, 03:00 PM | #31 |
For the rear brakes I initially planned to go with CaptainFabs D52 brackets with the Astro Van rotors and Caddi calipers so that I could still have an e-brake. But after lots of searching and junkyard calling I was coming up short on the parts I needed for the caddi e-brake
So I came across the D154 e-brake kit from Wilwood and since they matched the D52 style front caliper and had an internal e-brake I went that route Using the Wilwood/Lokar ebrake cable kit with them hooked to the factory under the dash ebrake lever I've been extremely happy with them and if you read reviews about them not holding well as an ebrake it is because that owner did not properly adjust them. There is a adjustment wheel on the inside of the bracket on each side you must set the internal brake shoes with. Since doing this mine have worked great
04-16-2013, 04:17 PM | #32 |
For a rear swaybar I went with the Hotchkis Double Blade Style Adjustable Sway Bar and it worked out well with all my other components
04-16-2013, 06:15 PM | #33 |
And here's some shots of the rear setup done
04-16-2013, 06:18 PM | #34 |
More
04-16-2013, 06:36 PM | #35 |
04-16-2013, 06:39 PM | #36 |
04-16-2013, 06:40 PM | #37 |
Looks great. Subscribed.
Posted via Mobile Device |
04-16-2013, 07:47 PM | #38 |
Nice transformation! I'm in.
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans Project Dooley One-Ton 4x4 on 38.5s Corn-binder build |
04-16-2013, 08:19 PM | #39 |
Very cool truck
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
04-16-2013, 08:35 PM | #40 |
I have the same truck. I am rebuilding it from the frame up. I have been working on my truck for about 9 months. I pulled the worn out in line six out and installed a 350 4 bolt.with a auto transmission. Stay with your orginals thoughts. If you are in dought, then investigate what you are doing first and then do the job. I can tell you about that. I have done some things two and three times to get it right. I have posted a lot of pictures on my site. Good luck and God Bless
05-19-2013, 01:44 AM | #41 |
What are the spec on your wheels?
05-22-2013, 11:39 PM | #42 |
Here you Go - Ill put more detail when i get back to updating the thread
Front 20x8 4.75" BS Tire Size 255/40/20 Rear 20x8 4.375" BS Tire Size 255/45/20
05-23-2013, 01:17 AM | #43 |
hey buddy nice looking truck great write up
07-30-2013, 09:55 PM | #44 |
Back on with the updates, I've been lucky enough to enjoy the truck at a few events but a few shots of that to come later...
On to the front Here's some shots to show what I was working with factory and drum brake setup
07-30-2013, 10:18 PM | #45 |
Unbolted everything from the front end, then spent the time de-greasing, wire wheeling, rust converter and some chassis black to clean everything up to match the rear
07-30-2013, 10:25 PM | #46 |
Neat Shot of the front end floating i thought
07-30-2013, 10:44 PM | #47 |
For re-assembly I went with:
'68 SWB Stepside - Inline Long Six 250 C.I. (LS250): http://67-72chevytrucks.com/vboard/s...ferrerid=83901 Last edited by RdoubleU; 09-03-2013 at 10:13 PM. |
07-30-2013, 10:47 PM | #48 |
07-30-2013, 10:50 PM | #49 |
With everything re-assembled you can see how it all comes together including the shock relocators.
I had no issues with anything during assembly and the control arms from Nate are top notch with the flexibility to run bags one day if wanted
07-30-2013, 11:11 PM | #50 |
Also on a side note: I also replaced the Lower Control Arm U-bolts
NAPA Part # 650-4065 http://www.napaonline.com/Catalog/Ca...065_0373628926 I did have to drill the factory holes out alittle to have them fit due to the larger diameter but it was fairly simple task
