Old 04-16-2013, 07:32 PM   #1
thesickc10
spindle help
i have belltech 3 inch drop spindles for the 1.25 rotors or at least i hope i do i bought them used (never installed). They say 9903 on them but i cant find that as a belltch part number. I went to install new wheel bearings and the inner bearing doesnt fit the spindle part is thinner than my stock ones. Im gonna call belltech tomorrow but can anyone pass some info my way? im nervous i bought knock off garbage.
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 04-16-2013, 07:48 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: spindle help
Belltech will be either #3100 for the Hd 1-1/4" rotors or #3200 for the light duty rotors.
I think someone got you.
Keith
Convert to disc brakes.
Old 04-16-2013, 07:49 PM   #3
lolife99
lolife99's Avatar
Re: spindle help
HD spindles use the A5 inner bearing.
Light duty spindles use the A6 inner bearing.
Both use the A3 outer bearing.
Keith
Old 04-16-2013, 07:51 PM   #4
thesickc10
Re: spindle help
Good thing about that is i have his address from ebay so i know where to go to cut his hands off.
Old 04-16-2013, 07:52 PM   #5
thesickc10
Re: spindle help
There is also the number 31200 on them.
Old 04-16-2013, 07:56 PM   #6
lolife99
lolife99's Avatar
Re: spindle help
That's different.
You may have the correct part.
If the upper balljoint fits,... it's a 73-87 spindle.
Belltech has a 3120 which is a 71-72 spindle.
You're going to have to check the upper ball joint or outer tie rod to know for sure,...
Keith
Old 04-16-2013, 07:57 PM   #7
lolife99
lolife99's Avatar
Re: spindle help
Either way it sounds like you have a different spindle than what is on your truck.
Keith
Old 04-16-2013, 08:01 PM   #8
thesickc10
Re: spindle help
Its on the truck all the balljoints are in. I was told it there were for 1.25 rotors which is what i have maybe the problem is they are for the smaller rotors. It doesnt help that i have a terrible italian temper either haha.
Old 04-16-2013, 08:03 PM   #9
lolife99
lolife99's Avatar
Re: spindle help
If they fit the balljoints,... they are 73-87.
If they don't fit the 1.25" rotors,... they are the light duty 1" version.
You can just change the rotor,... but that will also require a caliper change.
Keith
Old 04-16-2013, 08:06 PM   #10
thesickc10
Re: spindle help
Anyone wanna buy some light duty drop spindles? haha just my luck looks like were getting new brakes!
