Old 04-16-2013, 09:31 PM   #1
dlong67
Wheel Offsets - drop w/cpp modular spindles
Hey guys, I'm starting to plan on the drop for my Burb and need some advice on wheel offset. The truck is a 70 model with the wider rearen from 71-72. I'm planning on doing a 3-4 drop using the CPP modular drop spindle in front so I'll get an extra 3/4" reduction in track width per side. I'm planning on going with 20x8 up front, or maybe 9.5 if it might fit. I'd like to run the same wheel in the rear if possible so I could rotate tires. Can anyone recommend an offset/backspacing for this combo? I searched the board and can't find much mention of backspacing when using the modular spindles.
dlong67 is offline   Reply With Quote
Old 04-17-2013, 01:38 AM   #2
oldspowered67C10
Re: Wheel Offsets - drop w/cpp modular spindles
I have the modulars, 0 offset is about right, thats 4.5" bs on a 20x8 or 5.25 on a 20x9.5. Should work nice on a late width rear end. 9.5 should fit with that drop but with much more drop that might be a bit too wide up front. I have 20x8.5 up front w/ 4.75 bs and 20x10s with 5.5bs in the rear, have to run 3/8 spacers in the rear but thats with a early width rear end.
oldspowered67C10 is offline   Reply With Quote
Old 04-17-2013, 05:26 PM   #3
no_rice
so im assuming your doing the modular drop spindles that are 2" and some shorter coils to make up the rest?
no_rice is offline   Reply With Quote
Old 04-17-2013, 06:55 PM   #4
dlong67
Yeah, I talked to one of the Tech guys at CPP and he said he had a spring which would add a little more drop in the front to go with the modular spindle.
Old 04-18-2013, 01:34 PM   #5
no_rice
gotcha was just wondering about the 3" drop with 2" spindles... lol
